Results 1 to 14 of 14
Thread: dual/triple reservoir placement
    Nov 2016
    I've stumbled across this info before, but can't find it now.
    I plan to mount reservoir similar to the image below.
    How far forward from the front of the foot box can these be mounted before I have interference (with the strut for the hood I believe)?
    Fairfax Station VA
    I placed the near reservoir about 5" from the front of the foot box, and just barely clear the strut with the far reservoir.
    IMG_2062 by jhsitton, on Flickr
    MK IV Roadster #8631
    Nov 2016
    Do you have a measurement from the foot box to the far reservoir? I have different reservoirs that what I had pictured. Thanks!
    Santa Clarita, CA.
    The strut brace is right at about 12" from the front of the foot box at the 3/4 top square tube.
    Nov 2016
    Perfect - I think this markup is showing what I'm asking for and Papa has provided.
    Leesburg, Va
    Make sure that when you mount them that they are higher than the master cylinders. I almost didn’t mount mine high enough.
    Doug
    FFR 7995
    347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
    Senior Member RickP's Avatar
    Boyertown, PA
    CDXXVII
    Not to hijack this thread but where did you get/obtain the back mounting plate for your reservoir mount? I am in the process of converting my single FFR kit supplied reservoir to a dual CNC setup and need to get a little creative with mounting them. If I'm going to go through the hassle of doing this, it sure would be nice to back the reservoirs with a nice shiny piece such as the one you show.
    Santa Clarita, CA.
    The picture I posted earlier was actually a photo I found when I was trying to figure out how to install mine.
    This is mine.
    I made the backing plates. It's actually a little overkill. One piece of sheetmetal with an angle bent at the top attached under the 3/4" frame tube sandwiched with a second of the same shape attached to the back of the 3/4" frame tube.
    Quote Originally Posted by RickP View Post
    CDXXVII
    Boyertown, PA
    That's pretty darn sweet CDXXVII
    West Linn oregon
    In relation to the frame that the Triple CNC mounts to in the pictures shown, are the top of the caps even with the rail?
    Lilburn, GA
    Here's a view of the max measurement from the footbox to the hood support. I lowered the hood and inserted my finger, in-line with the rear of the support mounting bracket. Approx 12 1/2"
    West Linn oregon
    Do you mount the reservoir level with the ground or follow the angle of the frame?
    Thanks again.
    Santa Clarita, CA.
    I mounted mine level to the ground. Not sure it makes a difference but i tend to overthink everything.
    Quote Originally Posted by bluse View Post
    Thanks again.
