Goofy Odometer Behavior
Today on the drive home, I noticed my odometer was running at breakneck speed - approximately 1 mile per second! Even when completely stopped! I shut the car down when I got home, and then restarted it in the garage. The odometer was no longer counting up. I have not taken it for a second drive, so I don't know if a power cycle "fixed" the anomaly.
While driving, the speedometer appeared to behave normally; only the odometer was wonky.
I have the Speedhut classic gauges, no GPS.
Has anybody seen this problem? Thoughts as to its origin?
MK IV Roadster #8631
It is a fault in the speedo. Send it to Speedhut. They will fix for free.
