Likes Likes:  2
Results 1 to 2 of 2
Thread: Easy riv nut tool anyone can make
    Nov 2015
    Elverta, CA
    Like everyone else I have suffered the pains of getting riv nuts installed with the tool supplied in my kit as well as another similar aftermarket tool I've owned for years. I finally went back to the tool I used on RV stuff in my previous life. Here's a few pictures and you can see it is a simple piece of 1/8 steel measuring 5" long by 3/4" wide. At the end is a hole just big enough to fit the screw size you are using. In this case, I have drilled end 1/4" on one end and the other to fit a #10 screw. That's about the same as for the 3/16 pop rivits. At each hole lication, I punched 4 notches with a small chisel. These notches raise enough metal to hold the rivnut from turning.
    Simply run a grade 8 screw sized to your rivnut through a washer and then through the tool and install the rivnut on the side where the notches are, snug if by hand and install in in its location. I have used a simple ratchet and socket to tighten it as well as a 12v small making impact driver. Try it in a few samples and you will quickly be amazed at how consistent you can be installing rivnuts using this simple tool. Here's some pictures:15596882838552524665.jpg 1559688361095222258989.jpg15596885425791859366586.jpg15596885844032037370184.jpg.. try it, you will be amazed at the simplicity.
  2. Thanks Ty's33 thanked for this post
    Likes JOP33, GoDadGo liked this post
    Rotonda West Florida
    interesting, thanks for sharing!
    FFR 35 p/u # 0014
    I used to think I needed a Rolex watch, now I’d be happier with a Swedish K!
