Results 1 to 11 of 11
Thread: Remote positive post
    herb fraser's Avatar
    I installed a remote positive post on the firewall just in case the battery dies, thought it might be a good idea instead of climbing under the truck bed
    Lost Wages, Nevada
    Just one question . . . why not put a [second] remote ground post there too??
    Doc
    Doc
    Because any of the metal surface is a negative ground so it’s not needed
    Ok, where do you plan on putting the negative clamp? What about arcing and the teeth scratching the surface?
    Quote Originally Posted by UnhipPopano View Post
    Thanks for your concern but there are many places to clamp the negative clamp like the engine mount , the ground strap, any of the many bolts, etc. that wont matter if the teeth bite in
    I have always been taught that you connect the dead battery so arching on the negative connect is not a concern
    For the so few times that this may happen
    I see no issue, although I might be wrong
    There are many new cars that have remote battery locations like my Mercedes Benz and Jeep Grand Cherokee and have positive remote post and no negative post doesn't really make since to have one as but if that what you want its your build so go right ahead
    Loveland, CO
    I'm with Herb on this one, considering where the battery is located. I am still struggling with how to get the battery out if necessary. They say it can be done, but has anyone tired. May need to consider re-location, or hole in the bed. Just saying.
    Ralph
    Bourne-Cape Cod, MA
    Quote Originally Posted by herb fraser View Post
    Herb-you are 100% correct. rock on!
    Arcing is not a concern if the connection is solid before a load is applied anyway.
    FFinisher/AKA RE63
    Oct 2018
    ada minnesota
    from a security standpoint is a live feed to jump ignition a good thing?? or is the hood secured so thieves stay out??
    on my other street rods I have a battry cut off and chain and lock hood down
    last year they tried to get under the hood 2X but give up
    Heart of Dixie, Alabama
    Used to just touch bumpers, then put the positive jumper cable on the batteries.
    Quote Originally Posted by Houdini View Post
    The positive side of the starter is always live anyway
    that was the good old days ! when bumpers were bumpers LOL
