Thread: Okay to run fuel pump with out ECU
    Jan 2016
    15-17 coyote crate and harness.
    Is it okay to run the fuel pump independently from the ECU system? I am thinking of wiring a fuel pump on/off switch for added safety and security. Will this affect the ECU function?
    Norton, MA USA earth
    Shouldn't be a problem
    Mike is right, of course. Wouldn't be a problem. But another option to give both -- switched plus managed by the ECU -- is to put a simple SPST switch in one of the inertia switch wires. Break the ground and the fuel pump relay in the RF fuse panel is opened. Did this on my #8674 Roadster build and works as expected. The switch is on the center panel under the dash.
    Colorado Springs
    I agree with edward. I think it's important for the ECU to control the fuel pump. If you get in a crash and the engine stops, so will the fuel pump. If it's wired separately, the pump will continue to run until you shut it off. That could be a real fire hazard.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Jan 2016
    The ineritia switch works by impact correct? For example you get in an accident and the inertia switch will shut down power to fuel pump?
    I am using the infinity box (isis) system. I have all the options to wire the pump through; ECU, ignition switch, or seperate mechanical switch. I was planning on putting inertia in regardless.
