Welding axle brackets on 3-link setup necessary?
I was just wondering if I should weld my axle brackets on 3-link setup to the rear end? rear end is already off to get to get rebuilt and the guy doing the work can weld it if I want to. Is there any special adjustments to get pinion angle other than the adjustable arm on top? If so I probably would lean towards getting it all dialed in then welded. seems like a lot of stuff on this kit needs some kind of macgyver tweaking that the build manual doesn't show. haha
or should I just leave it bolted and forget the welding idea?
