SBC/Tremec Transmission Mount Spacer
Trying to determine the Transmission Mount Spacer dimension to get correct Alignment/Clearance for the Drive Shaft. I temporarily just set the Yoke on a 1/4" piece of plywood to get an approximate height. How critical is this dimension. I did modify the SBC Engine Mount to clear the Front Pulley by machining Bushing to move the Engine back about 1/2">>
