Thanks Thanks:  3
Likes Likes:  3
Thread: Yearly safety inspection
    Jun 2018
    Hi guys I know I've seen it before I used the search function but couldn't find it. Is there a list an inspection list of what we should look at lube, examine etc when we pull our cars out of storage for a driving season? I'd appreciate it if you guys could point me to it.
    thanks in advance
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Here is the list I use:
    Drive Line
    □ Radiator hose’s - squeeze lower - checking for softness
    □ Fan blades - look for cracks
    □ Transmission fluid
    □ Clutch cable - open cover and check end of cable - it tends to break at the lower end of the cable
    (also check where cable leaves engine compartment that it's well away from exhaust!)
    □ Check the 2 bolts for the shifter handle (on the T5 transmission)
    □ Clutch inspection cover to have a look at the clutch disk
    □ Check under side of side exhaust pipes where rear bracket welds to the side exhaust for cracks
    □ Driveshaft Bolts (Grease)
    □ Header Bolts, Exhaust System
    □ Belt(s)/Pulleys or replace them every 70,000 miles
    □ Carb- check-replace fuel filter(s)
    □ Rear end fluid level
    □ Change Oil
    □ Coolant Level / Condition
    □ Fuel Lines
    □ Engine / Transmission Mounts
    Suspension / Brakes / Steering
    □ Clean and repack wheel bearings (replace them at 100,000 miles)
    □ Brake fluid - flush and replace at 100,000 miles - or not a bad idea after hard day at open track event!
    □ Inspect brake flex hose for rubbing on shocks and that plate you attached to the frame is still tight
    □ Look closely at rear flexible brake hose - ends to be sure it's not been stretched
    □ E-Brake cables that "slide" under the frame pipe - look for wear
    Check the short e-brake cable
    □ U joints for wear - move up/down side to side - there should not be any movement in the joint
    □ Tie rod ends & ball joints (Grease)
    □ A-Arms (Grease)
    □ Rear Control Arms (Grease)
    □ Ride Height (in case of sagging) = Front 4”/ Rear 4.25”
    □ Shocks (ride height torque = 55 max
    □ Brakes pads and/or shoes
    □ Calipers
    □ Brake Lines
    □ Steering Linkage (all fasteners)
    □ 3-Link Mounts (Grease) large = 120 max, smaller = 85 max
    Other
    □ Battery mounts - check bolts make sure they are tight!
    □ Wire connectors, all you can reach
    □ Seat bolts/nuts
    □ Seat Belts
    □ Fire Extinguisher
    □ Body Mounts
    □ Bumper Mounts
    □ Wind Wings / Visor mounts
    □ Light Bulbs
    □ Tire Pressure __24_F, __24___R
    □ Lug Nuts Torque = 85max
    □ Fuel Filler
    □ Door Latches
    □ Mirrors
    □ License Plate Mount
    Torque Specs according to FFR Build School at Mott Community College hand out material and documents
    Front suspension
    Upper control Arms adjustment bolts 60
    Upper control Arms mounting bolts 100
    Bracket (Spindle) 70
    Shock (bottom) 70
    LCA 110-150
    Shock Bracket (Lower Arm) 55-70
    Ball Joint (upper) 80-120
    Ball Joint (lower) 80-120
    Rear Suspension
    Upper control Arm to axle 70-100
    Upper control Arm to frame 80-105
    Lower Control Arm to axle bracket 70-100
    Lower Control Arm to frame 80-105
    Lower Control Arm Bracket to axle 90
    Shock Bracket, Lower 55-70
    Shock, Top 25-30
    Shock bottom 45-60
    Quad Shock bracket to frame 56-70
    Quad Shock to bracket 56-70
    Quad shock to axle 56-70
    Rear Suspension (3-Link)
    Pan hard Bar 250
    Upper frame mount 90
    Rear Suspension (IRS)
    Rear Axle nut 250
    Shock (upper/lower) 70
    Spindle attachment 100
    Driveshaft to center section 70-95
    Steering Rack/Shaft
    Steering Rack Bolts 30-40
    Tie Rod Ends 25-35
    Pillow blocks 20
    Exhaust
    Straight Pipe 35
    Engine/Transmission
    Transmission Mounts (Tranny to mount) 25-35
    Transmission mount (Mount to frame) 25-35
    Engine mount (Engine to mount) 35-60
    Engine mount (Mount to frame) 50-105
    Driveshaft bolts 70-95
    Lights/ Trim accessories
    Windshield 90
    Quick Jacks 60
    Body Bolts 20
    Miscellaneous
    Wheel lug nuts 80-105
    Pedal box (front plate upper) 35
    Pedal box (Frame down tube) 10
  3. Thanks Just puttering, Mark Eaton, Geoff H thanked for this post
    Likes Dewey McBride, Timojen liked this post
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    Great list. I'm a safety loonie, so I'm going to steal this and use it when the time comes. Thanks!
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
    Jun 2018
    Thanks Ray
    mburger's Avatar
    Punta Gorda FL
    Thanks Ray. Copied this out.
    Mark
    Jax Beach, FL
    Don't forget to check the upper control arm pivots for binding. The older type is prone to this.
    Torque the intake manifold.
    Very extensive list.
  8. Likes Yama-Bro liked this post
