0
0
Coyote clutch switches
I cannot find the answer anywhere on the forum.
I am hooking up the upper and lower clutch switches but there is apparently no lower pigtail on the coyote harness to plug into. The upper switch has a corresponding plug which I guess is the safety switch since it is engaged when the pedal is depressed)
The lower switch does not have any corresponding plug on my Coyote harness. When I say lower, I mean the switch that is lower than the top switch that is labeled “clutch bottom”. The harness is part # CM-14A006A504VB Rev 1
Any ideas?
Thanks in advance.
Scott
