Thread: Clicking sound when I depress the clutch pedal on my MK2 roadster
    It seems like almost every time I press on my clutch pedal, I hear a loud clicking sound coming from my pedal box. Any ideas? [email protected]
    Fairfax Station VA
    Hydraulic or cable set up?
    MK IV Roadster #8631
    Member Jim Doak's Avatar
    Midway, Utah
    Clutch interlock switch?
    It's a contact switch located on the clutch pedal that activates when you depress the pedal. (Typically comes with cable-actuated clutches.)
    Mk 1.5, 347 with Sniper EFI, T-5, 3-Link with VPM Rear Sway Bar, Power Steering with Hydraboost Brakes, Under Car Exhaust, SAI Mod, Rear Fender Flares, Dropped Trunk Mod, ... (Sold September 2019)
    Forte's Parts Connection
    mike forte's Avatar
    Framingham, Ma.
    Hey Minimotoman,
    Assuming that your MKII has a stock pedal box and its a cable driven clutch? Check the cable by the top of the firewall and bell housing for any fraying.
    This is a common problem for the Mustang cable & more so aftermarket cables.
    Mike Forte: Forte's Parts Connection / Framingham, Mass. 01702 / 508 875 0016 / [email protected] / fortesparts.com / Facebook Instagram: @fortespartconnection Est: 1981 dealing performance parts to build your dream car. A REAL SPEED SHOP with parts, price & knowledge. Developer of the early Ford & FE Tremec and Mustang firewall adjustable quadrant kits, external slave clutch release conversions & cable release conversions. Tremec Elite, FORD RACING & QUICKTIME DISTRIBUTOR!
    Grand Rapids, MI
    If you have a cable clutch and the new Wilwood pedal box the quadrant may be assembled wrong. The clutch cable end will nick the pedal box causing a click. Or as others have said it may be the neutral safety switch as they click but are not usually to loud. If it’s a stock pedal box worn pedal pivot shafts cause that noise.
    Quote Originally Posted by mike forte View Post
    Hey Minimotoman,
    The cable most often frays just inside the pedal box where it is nearly impossible to see. See 'A'. They sometimes also have a problem where the large diameter piece that fits into the firewall cup starts to work it's way up the outer sheath. See 'B' In this case the clutch pedal usually gets lower and lower towards the floor. Flickr is inop so I will get a pic here later. BTW, if it's your cable, get a real Ford cable from Mike.
    clutch cable 2 by craig stuard, on Flickr
    I've looked at all the options and I'm going to say it's your left ankle......When's the last time ya had a check-up,,,,,you should take better care of yourself,,,,,you're not as young as you used to be...… When you were born the doctor slapped your mother......If I had a dog that looked like you I would shave his...………..WHOA! sorry brother. I had radar lock and couldn't hit the "ABORT" button. Too much "G" force.....or paint fumes...da Bat...…..am I a funny guy or what ?......hello, anyone, anyone.....I'm getting my money back !
