Ford racing 90mm throttle body with coyote gen 2
Hey guys, i’m In the end of my build.
I got a 2015 coyote engine with a 302 boss intake manifold.
I installed a 90mm Ford racing throttle body. Once installed I noticed that the T-B connector is mâle and so is the wire from the engine.
Would i be able to simply put a femal connecter or the wiring is different on the Ford T-B ?
Pretty sure when you buy that manifold new from ford, it came with a new connector to fix this problem. Maybe contact ford racing.
