Thread: Speedhut gauge accuracy
    Grand Rapids, MI
    I’m not sure if any one else has had this problem by my speedhut oil pressure gauge will read a constant say 30 psi at idle or 47 psi driving. Then every now and then maybe 1 minute intervals it will drop 5 psi for 10-15 seconds then it returns to its previous reading. Wiring is the Ron Francis harness and voltage is stable and clean. A mechanical gauge shows solid numbers so I know it’s the gauge. Kinda not had awesome luck with that gauge as I’m on my second sending unit which seems to be common with them. And to top it off the head light switch from time to time has some internal connection issue where with the gauge lights turn off with all the running lights working then with a wiggle of the wires they magically they light back up. Car only has 212 miles and I’m woundering about the durability of some of the FFR electrical parts. Don’t get me wrong I like the Ron Francis stuff it’s the other bits.
    Cape Coral, FL
    Quote Originally Posted by GFX2043mtu View Post
    Did you use the oil pressure wire in the harness or use the yellow pigtail wire that came with the gauges? I talked to FFR and they said and Speedhut confirmed that you should not use the wire in the harness and run the yellow wires out to the sending unit from the gauge plug in. I think the gauge doesn't like the ground through the harness and wants two separate wires directly from the sender to the gauge.
    Grand Rapids, MI
    I’ll have to try using the the supplied wires as I used the wires in the harness.
    Member Dewey McBride's Avatar
    Fairfield Ca
    From what I've read, there are a lot of issues with the Speed Hut Oil Pressure gauge. Mine will fluctuate a lot while driving. As long as it's reading pressure, I don't worry. It'll be at 30 when I'm at idle, 50-60 when driving, but 100 when I'm on it. I haven't really noticed a problem. My GPS Speedometer did not read for a whole day. After I contacted Speed Hut about the problem it magically started working again with no issues.
    I've had 3 or 4 Speedhut OP senders fail when installed directly to the block but none when I have remote mounted them with a section of braided hose between the block and sender. It seems they can take vibration.
    Heart of Dixie, Alabama
    I have the same issue, occurred after about the 3rd start on the engine. Pretty sure I used the Speedhut wiring, but will confirm. Mine drops from 60 to 30 fast and about the time you start to panic, it goes back to 60 or higher.
    BadAsp427's Avatar
    Greeneville, TN
    FWIW, I had to run a ground wire to mine... It would not work with only the ground through the threads into the block. Also, when the key is on and engine is not running, mine never goes below 5PSI, but seems to show PSI when running... about 65PSI on my 347ci BluePrint engine.
