Thread: E-brake boot mounting
    Nov 2016
    Petaluma, CA
    I'm looking for some close up pictures of the e-brake boot and options for mounting it to the transmission tunnel. I guess sheet metal screws will work but is that the best way? Help!
    Thanks, Joel
    Sheet metal screws will work fine. I used black colored screws, with finishing rings to match the boot. They have remained solid since day one.
    Aug 2018
    Hampshire, IL
    I think its replicarparts that has a nice Crome trim ring to fit around it and finish it off.
    Nov 2016
    Petaluma, CA
    Thanks to all for the responses. Joel
