Results 1 to 12 of 12
Thread: Donor front brake caliper question
Hybrid View
    Senior Member Cobradavid's Avatar
    League City, Texas
    Question Donor front brake caliper question
    My passenger-side front brake caliper isn't releasing fully and it drags on the rotor a little. It doesn't drag enough to make the roadster pull to that side, but there is slight resistance to rolling.
    Also, after diving the car a dozen miles or so, that wheel is hotter than the driver-side wheel.
    I've removed the caliper and cleaned and lubed the mounting pins and surfaces but the problem hasn't gone away.
    Build specifics:
    2001 Mustang GT hydraboost master cylinder and hydraboost unit
    2001 Mustang GT brakes (the PBR calipers). Donor had ~46k miles.
    New pads installed when I built the roadster. The roadster has 13k miles and there have been no issues with the brakes prior to this.
    Any thoughts on what could cause this dragging?
    My Saving Grace: John 3:16
    FFR6687, Graduate #39 in the Class of 2009
    The Factory Five Forum March 2012 POM
    Maricopa AZ
    Check the pushrod on the pedal and make sure you have some freeplay
    Dec 2017
    Gordon, could you expand on that a little?
    Maricopa AZ
    OK, when you hook up the brake pedal to the push rod, some use and adjustable push rod. Somethings the jam nut comes loose and the rod starts putting pressure on the master and the brakes start dragging. An easy way to tell is that the brake pedal has no freeplay. You need to have a little or this issue can arise
    League City, Texas
    Thanks for the assistance, Gordon.
    The brake pedal has a little free play. Also, I don't see any jam nut between the pedal and the push rod. I used the stock pedals and pedal box from the 2001 GT. Is an adjustable push rod an after-market part or was that stock?
    Only the passenger side front brake is dragging, the driver side turns freely and that wheel doesn't get warm after driving like the passenger side does. Would the push rod jam nut affect just one side?
    When checking the pedal play and looking for a jam nut, I noticed a drop of ATF/power steering fluid on the brake pedal push rod, so I guess the hydraboost unit has a slight leak. Could that cause one corner to drag?
    Is there a caliper rebuild/replace task in my future?
    Quote Originally Posted by Cobradavid View Post
    I think so. The composite pistons in the PBR calipers have a reputation for sticking.
    League City, Texas
    Thanks, Gordon and Jeff for sharing your expertise!
    Will a caliper re-build fix this or should I just bite the bullet and replace the front calipers. I'm a government employee and I'm not getting paid right now with the government shut-down, so I need to watch the expenses!
    Maricopa AZ
    You can replace 1 but I always do them in prs. You should be able to get rebuilts from your local parts house pretty cost effectively.
    Member FlyingCobra's Avatar
    I'd replace the caliper with a rebuilt one. Rebuilt front calipers are pretty inexpensive, and I would replace it. I've had this issue on Fords over the years. If you check your local parts house or Rock Auto, you can find one pretty cheap. I usually buy mine locally from Advance or O'Reilly.
    It generally is considered better to replace the calipers in pairs to keep things even. That said, I have replaced single calipers on several occasions when they've stuck and I've never observed adverse effects from it. So if you're tight on funds now, I'd just replace the single caliper and that will probably work just fine for you.
    League City, Texas
    Thanks, guys! A pair of replacement calipers is the plan now.
    Check Amazon as well, Sometime you can get excellent prices and free shipping.
  12. Thanks Cobradavid thanked for this post
  13. #12
    Just replace the one that is sticking. I know a lot would say do both and that's fine if one wants to be preemptive. You could replace the rotors and pads too. You could replace the rears too. But if your budget is tight, fix what is wrong and move on.
