Likes Likes:  2
Results 1 to 10 of 10
Thread: Cutting holes is body and waterfall for the door hinges??
    Placitas, NM
    Seems the manual doesn't have much info other than the top hinge hole cutout. Maybe I missed it if there is more info.
    Did you guys find something I missed?
    Oct 2014
    Vermilion, OH
    I just went back though the manual and I don't see anything about the lower hinge. If my memory is correct I did the lower hinge just like the upper hinge. Once you cut the upper hinge hole out the lower will make more sense.
    CVOBill
    Apr 2014
    Memphis, TN
    It doesn't really ever say, I personally watched Eric Hansen's videos and "The Compound" videos on youtube to work through how to put the doors together. Super helpful. Links below.
    https://www.youtube.com/watch?v=Qled...&t=0s&index=22
    https://www.youtube.com/watch?v=jOzxgY01t9k&t=11s
    Ryan
    33 Hot Rod
  4. Thanks Mrallsport32 thanked for this post
    Likes wrp liked this post
    Placitas, NM
    Thanks for the info Bill and Ryan. Those links are very helpful.
    I was planning on doing the hinges yesterday but decided to get the roll bar to fit (without having to hammer it in place) and then cut the holes for it in the waterfall.
    After I finished the above I need to dig into the manual more, don't remember seeing the sides of the waterfall overlapping the hinge area in other posts or videos.
    Did you guys have these big gaps too?
    Also the link showed the hinge bracket is positioned 5/16" above the frame, the manual said 1/8" which is where I have it now. Which is correct?
    Oct 2014
    Vermilion, OH
    I massaged and refit the waterfall and pulled it in with trim screws. I set the height at 5/16" on the hinge bracket.
    CVOBill
    Placitas, NM
    Bill, thanks. I just looked at the manual again and see it does say 5/16, I think I got the 1/8" from the space to leave above the door hinge standoff to account for the brass bushing.
    Gatineau, Quebec, canada
    This is how we ended up once setup.
    20181223_185703.jpg 20181223_185709.jpg 20181223_185715.jpg 20181227_151250.jpg
    I ended up using 10-32 Rivnuts so i can easily remove the waterfall if necessary.
  9. #8
    Placitas, NM
    Thanks AJT, I like the clamp method of pulling it into place and that cutout so you can remove the waterfall without messing with the door hinges.
    I'll be using rivnuts on the waterfall too.
    It would have been so much easier if we had a template to use to cut the holes.
  10. Likes AJT '33 liked this post
  11. #9
    Mar 2018
    Yucaipa, CA
    Hey, thx for this good post. I will be needing this info when I get as far along as you guys...
  12. #10
    Yes they over lap. Need to cut so they are not in the hinge openings. I set the standoffs at 5/16. Had to adjust one of them to make the door correct.
