I am having an extremely difficult time getting the body of my early serial number Gen 3 coupe to mount even close to how it should.
The problem is when the rear of the body is set to the height specified in the manual, the right door sill is up off the frame about a ½ inch in the back. Also, the door opening at the top, rear, is almost above the top roll bar. The drivers side looks perfect. In addition, the side to side wheel well measurement show the rear end about 1 inch to the driver’s side. If the body is pushed over the necessary amount to correct that, it only makes the door opening problems worse. I have exchanged e-mail and pictures with tech support and they have had some suggestions but I still have the problem. I have notched the body for the 1 ½ inch frame tubes and re-positioned the body at least 5 times to try and be sure it wasn’t binding on something. Has anyone had similar issues? If so, how were you able to resolve them? Any help will be greatly appreciated.
Gary
