Thread: Carb spacer clearance
    Jun 2018
    Hi guys Im thinking of adding this spacer to my 347 stroker: https://www.summitracing.com/parts/s.../applications/
    Its a 1" spacer, and was concerned about clearance with my hood. I'm running a 347 with a performer rpm (not an airgap manifold), the air-cleaner is a replica 289 hi-po https://www.summitracing.com/parts/sdk-c4dz-9600-c, quikfuel 600vs carb
    Think I'm ok with clearance adding a 1" spacer?
    BadAsp427's Avatar
    Greeneville, TN
    You should be able to put a short piece of 2 x 4 or perhaps a book or something that is about 1 1/4"- 1 1/2" on top of your air cleaner and then close your hood and see if it hits... If not, you should have no problem with a 1" spacer.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I have nearly that exact set up in my Mk3.1 and if fits fine. Only difference is I have a Holley 650 double pumper.
    Later,
    Mk3.1 #7074
    Jun 2018
    Thanks guys
    Remember that all 1" Spacers aren't created equal.
    4 Hole Merge:
    https://www.summitracing.com/parts/wsn-004110
    Open Plenum Phenolic:
    https://www.summitracing.com/parts/sum-g1405
    Divided Plenum Aluminum:
    https://www.summitracing.com/parts/edl-8714
    4 Hole Phenolic:
    https://www.summitracing.com/parts/sum-g1404
    Good Luck & Hope You Have The Hood Room You Need!
    Jun 2018
    4 Hole Merge:
    4 Hole Phenolic:
    Thanks that last one is the one Im looking at
