Likes Likes:  2
Results 1 to 3 of 3
Thread: Power Window motors???
    Placitas, NM
    I'm guessing the power window motor assy is a left and right hand?
    If so I think I have 2 that are the same.
    The bracket that mounts to them are a left and right.
    Figured one of you guys that have got this far will know as FF won't be open until Monday.
    While I was at it I at least got all of the small brackets powder coated today so its not a total loss.
    I also found the on-line window switch diagram has a small error in it.
    ^--This is from the on-line Door Install instructions.
    The info in the build manual, page 554 has the correct info for the switch.
  2. Likes erlihemi liked this post
    Senior Member JOP33's Avatar
    Haslet, Texas
    I also found out that the window switch diagram has a small error in it.
    Good to know, thanks for passing along the correction!
    Placitas, NM
    Heard back from FF, they are sending the correct power window motor assy today.
    I updated the info about the window switch in my post above.
  5. Likes HVACMAN liked this post
