Results 1 to 12 of 12
Thread: HF 2 Ton Engine Hoist on Sale
    Central Lake, MI
    Harbor Freight’s 2 Ton Engine Hoist is on sale now (with coupon) for the same price as the 1Ton. Picked one up today.
    30x18 1000lbs dolly is also on sale for 11.99 (vs 15.99) if you want something to set roll boxes or your engine around on.
    https://www.harborfreight.com/30-in-...lly-61897.html
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
    Cruzz-
    Thanks for the heads-up! That's a good deal for a tool that only gets used a couple of times.
    Thanks for letting us know!
    Sep 2015
    Beachside
    If you are looking for more uses, this is quite effective at pulling old shrubs out of the ground...
    FFR #8833 289 FIA 3-link
    Bakersfield, CA
    Or fence posts
    Build thread
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Or installing your IRS diff by yourself.
    JR
    Elk Grove, NorCal
    Dont forget to download their “20% off any one item” coupon also
    Kit purchased: July 25, 2017
    Member Kiwi Dave's Avatar
    Oct 2017
    Darnestown, MD
    Cruzz-
    .... you can increase the HF 2 Ton crane usage on your build by 50% if you use it to unload your frame from the UHaul you picked it up from the factory in:
    Senior Member Joe Campbell's Avatar
    Idaho Falls, ID
    One of y'all that has it, can you measure clearance from the hook to the hydraulic cylinder with the boom fully extended? Needs to be at least 5' to clear the body when it's installed. For when you have to do those catastrophic rebuilds or replacements....
    Tybee Island, GA
    Quote Originally Posted by Kiwi Dave View Post
    Amen, brother
    Videos are at: YouTube Videos
  10. Likes Kiwi Dave liked this post
  11. #10
    Oct 2017
    Darnestown, MD
    Quote Originally Posted by Joe Campbell View Post
    It is 46 inches between the hydraulic lifter bolt to the hook bolt at the 1/2 Ton maximum length:
    I am an 818 builder, so not sure if this applies to other FFR kits but likely it does, the HF 1 Ton crane reach is too small - 2 Ton is the way to go. Like anything from HF, double what you think you need!!!
    Cheers
    Oct 2017
    Darnestown, MD
    Quote Originally Posted by DadofThree View Post
    Amen, brother
    I believe it was you who gave us the idea - thanks Dave!
  13. #12
    Tybee Island, GA
    Glad it worked out
  14. Thanks Kiwi Dave thanked for this post
