Results 1 to 3 of 3
Thread: Orange turn signal light
    Accord NY
    Is it normal for the the chrome trim ring on the front orange turn signals to not touch the body when installed?
    Craig
    Chino Valley, Arizona
    Yes, you can use a large rubber O-ring to transition it in. Jeff Kleiner came up with the idea. Here is the dimensions:
    Accord NY
    Sweet. Thank you.
