I see that the headers have the stove pipe coming off to the rear of the heads, do I need to keep this tube ? Going EFI with air pump
If your state requires the EGR set up to be on the car, and I believe that NY does, you will need to keep that on your engine. If your state does not require the EGR system to be hooked up then you can remove the tubes and plug the ports on the back of the cylinder heads.
You do need to switch the stock headers on your engine to point forward in the Mk4 kit. Make sure you can still attach the EGR tubes to the headers if they are switched around to point forward.
Best regards,
Brian Zakrzewski
FFR Tech & Sales
thanks Brian, thats what I thought, but how do I run the tubing ?
