Results 1 to 3 of 3
Thread: Fastener re-use question
    Jun 2015
    Cool Fastener re-use question
    Good morning all!
    I'm in the process of building my MK4 and have the entire front end completed with donor parts but then broke down and bought the MK4 spindle kit instead.
    My question:
    Can I reuse all the fasteners or since they've been torqued once, do I have to replace all the nuts and bolts that I remove / replace? I understand maybe the nylock nuts but what is the general rule here?
    Thanks for any help you can provide.
    Phoenixmsb
    Bruce
    Saint Cloud, FL
    My understanding is that you only need to replace torque to yield bolts once used. The stuff on the suspension can be reused without any problems. Nylock nuts start to lose their effectiveness after multiple uses, so they may need to be replaced.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Kirkland, WA
    Don't know if the axle nut is the same for donor and spindle, but I would not re-use those. Don't cost much, very important fastener.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
