Thread: Room for another one
    Dec 2018
    Dublin, CA
    Hi from Norcal. Just purchased a previously started MK4 kit from a local guy a couple weeks ago. Actually, the only thing "started" was he loosely bolting the front suspension together 4 years ago and then life got in the way. I loaded everything up and it's now sitting in the garage ready to start again. I've spent the last couple weeks sorting through boxes and bags and getting ready to jump in. It's a pin drive IFS/IRS setup. Should be a fun project. I currently have a 1993 build Classic Roadster Cobra that I've had for about 6 years, but have always wanted to build my own some day. Well I guess today is the day!
    Congratulations and welcome. I hope you start a build thread!
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Oct 2014
    Vermilion, OH
    Welcome and welcome to the group.
    CVOBill
    Dec 2018
    Dublin, CA
    Thanks for the welcome guys. I'm still going through the assembly manual and verifying parts, but I thinking the book is vague, or should I say absolutely no information found on narrow width pin drive IFS or IRS suspension. It's looking like the kit came with narrow width pin drive lower control arms, but the spindles are stock FFR MK4 spindles, not the SN95's. Also with the kit are adapter brackets, #13819, but I think these are for standard width lower control arms, not narrow width pin drive?
    The IRS seems to be correct and all there. It could be that's why the previous owner stopped assembling the front after trying to mount MK4 spindles to the narrow lower control arms.
    Everything it torn back apart while I try and figure out what happened 4 years ago...
    Curt
    Quote Originally Posted by Bitten View Post
    Curt
    I can't offer any help with the pin drive setup, but there are folks here that certainly can. If you don't get a response to those questions in a day or so, try creating a new post in the Roadster forum with your specific question in the title and I'm sure you will get the help you need.
    Legal: 1/30/2020
    Curt
    FFR had a rash of mispackaged front pin drive width Mk4s a few years ago and several builders got snake bit (no pun intended) by it. You are correct; pin drive requires (A) Narrower front lower control arms, (B) SN95 spindles rather than the 2 piece FFR spindles and (C) specific spindle adapters #12507 as shown here:
    Compare this to the standard width adapters #13819 like you received and note how much closer in to the spindle holes the ball joint block is:
    The pin drive width instructions would have come as a supplement and are not in either the base or complete kit manual...in a nutshell you build the front suspension as if it was donor based and mount the UCAs using the top mounts rather than side mounts with the only difference being that it is assembled with the different lower arms and spindle adapters.
    As good as FFR is about taking care of their customers when errors occur since so much time has passed and you are not the original purchaser you may find that you have to eat the problem. Give them a call and perhaps they'll be willing to work with you on the cost of the correct components, some of which can be recouped by selling the 2 piece spindle set.
    Let us know how we can help and good luck!
    Dec 2018
    Dublin, CA
    Thanks for the info Jeff
    I’ll see if F5 is willing to swap parts before bit the bullet and order the correct parts
    Curt
    Senior Member gtaroger's Avatar
    Trenton Mi
    Welcome and congrats. Roger
    Nov 2016
    Welcome from a Type 65 newbie. Good luck with your build, I'll be following your progress.
