Results 1 to 11 of 11
Thread: Hello from Tejas
    Jan 2019
    Hello from Tejas
    Howdy All
    Rebuilding a MK3 in DFW...has a cammed LS based L33/TKO in it now and about 400 rwhp.
    Go-kart phase. About to finishing cleaning up the body and doing a wrap. My 6' 3" wifes legs are too long to fit in the passenger foot well, which has taken some wind out of my sails (she really isnt interested any longer).
    Wish I had got the road race MKIV for my purposes....and still may
    Cheers and thanks for the info on here to complete my build.
    Senior Member MPTech's Avatar
    St. Louis, MO
    Not sure how much room exists for an LS, but there is a PS FB mod that SIGNIFICANTLY increases the FB space for the passenger. Wider and LONGER. I started it in my club, and every build after mine that is aware of it has done it with no complaints. I know it is not practical for a Ford Mod motor, so may not be applicable for you (?)
    Senior Member TDSapp's Avatar
    Frisco, TX
    DFWMK3,
    What part of DFW you in? I am up in the Frisco area.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Jan 2019
    TDSapp
    In Mckinney.
    Thanks MPTech! I may have the room to mod and have thought about bending some metal. Thanks
    DFW,
    re: Larger passenger footbox - Here's how I did mine:
    It does yield a significantly larger footwell. I can definitely tell the difference.
    Worth looking into if you are running a small block and have the body off...
  6. Thanks DFWMk3 thanked for this post
    Likes DFWMk3 liked this post
    May 2018
    Sherman Texas
    DFW MKIII
    Welcome to Texas. I’m up in Sherman.
    Vette57
    Dec 2018
    Hi DFWmk3, I am in the process of planning a build and am also thinking of going LSx. Do you have a build thread? Im also in Texas
    Senior Member gtaroger's Avatar
    Trenton Mi
    Welcome to the forum. Enlarge the foot boxes and mount the seats all the way back . Should work. Roger
  10. #9
    Welcome Fellow Dark Sider, Welcome!
    I don't know where your LS is sitting; however, if you move it forward I'd bet money you will have room to spare for your long-legged better half.
    While I don't know if this video help or not, it can't hurt to take a look anyway.
    https://youtu.be/_wnHDNgnNqs
    The headers that I used are Schoenfeld IMCA 161-33.
    The same header for an LS is 161-33LS1.
    https://www.schoenfeldheaders.com/im...modified4.html
    For what it is worth, my engine is located on centerline with the side pipe openings and 1" to the passenger side of the car.
    Good Luck Fellow Dark Sider, Good Luck!
  11. #10
    Jan 2019
    Thanks for the info. I can definitely modify it for a few extra inches. Just unexpected.....she jumped in and said nope and has been uninterested since (that could be the new kid though).
    I'm sorry I don't have a build page but the LS is very straight forward. The mounts are welded to the stock mount risers. If I had advice, be careful with 2005-2007 truck engines...the L33 is a Z06 prepped 5.3 from the factory but its an oddball Gen 3/4 hybrid and parts aren't interchangeable. DBW corvette stuff fits great but u will pay extra, but after all the T/Bs, TAC modules and pedals I have tried, should have just used a gen 4 engine.
  12. #11
    Dec 2018
    Quote Originally Posted by DFWMk3 View Post
    Hi, can you elaborate on what makes them different and what parts are not interchangeable. I was actually thinking of going with a 5.3 liter I think 350ish HP is exactly what the cobra needs to be both fun and fast. TIA
