life got in way of truck and i took a break, went to japan for mooneyes show and got some done on car got engine and fuel system in, struggling with air and grill just had another flood and am thinking on moving getting too old to deal with winters here i stuck in stock 302 and camed it and took AOD and shift kit and 2200 rpm converter and i used a snow white converter and opel water pump and am going with carb to keep it simple for now not too many parts boxes left, a lot of modifications cause other problems and soon to be 75 year old
i run 3 transmission coolers and i water cooler ahead of rear axle and turned bat box and put in double u joint and hanger bearing i also had some parts plated last summer when i did a car show at dollywood
my dreams are to run dual exhaust to rear and put on a tube rear bumper so i may have to fix my exhaust bender i will run tailpipe under the rear end i hipe to get back up to speed on this now that every other thing has stoped
