Thread: Question for those with Moser rear end
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    My Moser rear end arrived yesterday. I notice that the lower control arm brackets look crooked/twisted, with both pointing outwards. Anyone else see the same on theirs, is this normal?
    Ron
    Loveland, CO
    Just looked at mine and they appear pretty square to the axle. The control arms mount at an angle, so maybe a change from mine.
    Welcome to the mayhem.
    Ralph
    Port St Lucie, FL
    Thanks Ralph.
    Guess I'll wait till I get the kit and connect the control arms to the rear. May be an issue, but not sure yet.
    Loveland, CO
    Mine fits fine, but I cant get it to stop leaking, and this if from just sitting. Don't want to take rear cover off, but may have to.
    Ralph
    herb fraser's Avatar
    Quote Originally Posted by rponfick View Post
    Ralph
    sure go ahead and take off the cover and reinstall then I am sure the leak will be gone
    Herb
    Mar 2013
    Medway, MA
    The rear lower control arm frame mounting distance is less than the distance between the axle mounting - they point in and forward. This is with the brackets hanging below the axle. Maybe you have your axle up-side down? If yours point out then seems possible they welded a right hand bracket to the left side and the left hand bracket to the right side.
    Port St Lucie, FL
    It all fit fine.
