0
0
Wiring Guidance
Being a little slow on wiring issues, I would like to get some guidance. Throughout the build there are circuits that need a switched 12 volts, and others that require battery 12 volts all the time.
The manual suggests using the choke wire in various places, if not using elec. choke (which I am), as a switched 12 volt source. I note that the choke circuit comes out of the Ignition feed area of the fuse panel.
Cannot you use any of the other switched 12 volt circuits, such as radio, heater, wiper, if not using these components?, but I see they come out of the acc. feed area of the panel. Is this a problem?
Likewise, cannot some of the memory circuits (speedo, clock) be used as 12 volt continuous battery leads in places requiring such, if not using the circuits for other purposes?
Thanks, Ralph
