Out of Sight Audio
Thanks Thanks:  2
Results 1 to 16 of 16
Thread: MK4 #7923 Donor Build SOLD
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    MK4 #7923 is up for sale. This is a donor build, but definitely doesn't look the part. Unfortunately my engine choice will probably hurt me, but it could be swapped out for something else. The car runs, and moves, but we haven't go karted it yet. With a partially built car the new owner would be able to make any changes without having to remove the body, etc. A great opportunity for someone to get a head start on a build with most of the work done. Body is untouched, in the condition it was delivered in.
    2004 Mustang Mach 1 DOHC 32 Valve 4.6
    Ceramic coated headers-uncoated painted side pipes
    Tremec 3650 5-speed with new RAM HDX clutch and pressure plate
    1994 8.8 completely rebuilt with new Yukon axles, Ford Performance gears 61.125 width
    FF 3 Link
    FF driveshaft
    99-04 front spindles
    New manual steering rack
    Rebuilt/powdercoated Mustang brake calipers with new pads and rotors
    FF tubular lower control arms
    Powdercoated frame
    Powdercoated engine bay aluminum panels
    Body cut outs
    Gas hood hinge kit-not installed
    Windshield wiper kit-not installed
    Self cancelling turn signals
    Standard FF bucket seats-not installed
    Dual chrome roll bars with polished trim rings
    Ron Francis wiring harness
    Ron Francis reflashed ECU to delete PATS and rear O2 sensors
    FF/Speedhut gauges
    New aluminum radiator
    FF/Halibrand replica 17" wheels
    New tires-Sumitomo HRZ 315-35 rear, 245-45 front
    Under hood battery relocation box
    New starter
    New fuel pump
    Tangent roll bar kit
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
  2. Thanks Starboy77 thanked for this post
    Great price. If I didn't already have three orphans here I might consider it.
    Fairfield Ca
    Don't sell the "Donor" short. My car used a Mach 1 donor and it's a really nice engine. Putting out 340hp/370ft.lbs. not to mention all the other goodies (power breaks, power steering, big breaks). That's a great price for your car.
    Thanks Dewey. Just seems like people shy away from donor builds, but yeah, I have seen some really nice donor builds.
    Have you thought about having someone like me or the other builders finish it for you? Then you can just enjoy it.
    You've Come So Very Far To Let This Dream Slip Away!
    If I get a vote, which I don't, I'd send it to Mike Everson or one of the other Master Builders to be completed.
    You work look excellent so far and you are likely 85-90% complete so the fun is about to begin sooner than later.
    Life got in the way of my build, which started four years ago today, but I'm back swinging wrenches and test driving the car.
    Good Luck & Don't Give Up Because You Are Closer Than You Think!
    Thanks guys. There is a whole lotta back story that I won't get into. I don't "have" to sell it. I have considered sending it out. If it doesn't sell that is most likely what I'll do.
    Dec 2018
    Wow the price is tempting, if I wasn't looking forward to the build so much I would save some cash and pull the trigger here. Someone is going to get a great deal.
  10. Thanks 3yearplan thanked for this post
  11. #9
    Quote Originally Posted by MSumners View Post
    Heck, for the money you can easily take it apart and put it back together
  12. #10
    PM sent
  13. #11
    Rleon, Bob, reply sent.
  14. #12
    Sale pending.
  15. #13
    Fortunately for me this car is staying in Michigan and I can see it when it's completed.
  16. #14
    Sold. On it's way home.
  17. #15
    Jan 2019
    Grass Lake, Mi
    I'm the new owner, or did I adopt? I want to thank Mike for being patient while I got my garage cleaned out and a trailer lined up to bring it home. This is a first for me and I hope to keep the quality build that Mike started going to completion.
  18. #16
    You will Dennis. And you'll definitely improve things as well. You were a true gentleman to work with and it was my pleasure to sell it to you. Hopefully the grandsons will have an interest as they get older.
    Mike.
