Thanks Thanks:  13
Likes Likes:  3
Results 1 to 33 of 33
Thread: The Last Mirror Is Gone!
    Hey Gang,
    Thanks to Edwardb, I've got a pair of the Factory Five Bullet Mirrors; however, I saw these the other day on a 356 Speedster Replica at a car show and man did they look elegant and didn't over scale that tiny rear engine cruiser.
    https://sierramadrecollection.com/Ae...T5-p20310.html
    Would these look like they belong on a Factory Five Roadster that is attempting to somewhat emulate the look of CSX-3178 which can be viewed via the link below:
    https://rmsothebys.com/en/auctions/m...sx-3178/380123
    So what do you all think? I'm at the final assembly stage before the body work gets started.
  2. Likes Mark Eaton liked this post
    I'd stay with the bullets because they look the part.
    But I'm looking into these after seeing a pair on a roadster this past weeked:
    https://www.jegs.com/i/Allstar-Perfo...76401/10002/-1
    They screw right onto the side pillar.
  4. Thanks GoDadGo thanked for this post
  5. #3
    They look OK but if you mount them in the same general location that the bullet mirrors usually go I fear that you'll experience the same problem that guys have with the bullet style---that being that you'll only see the hump in the rear fender. If you want to mix the vintage racer look with functionality I suggest you do what I did and go with Windshield post mounted Raydots (then do the mods I described in post #11 HERE).
    Dave,
    Those are the same as Speedway Peep mirrors, just cost about 2 1/2 times as much!
    https://www.speedwaymotors.com/Speed...Inch,3811.html
    I've put these on a bunch of cars and they work well if you mount them about half way up the windshield post.
  6. Thanks GoDadGo thanked for this post
  7. #4
    O'Fallon, MO
    Beat me to it Jeff. I used the Speedway mirrors on both my cars, they work good. But if money's no problem, buy at Jegs and pay way more.
    Steve, don't see how those you show, compare to #3178?
  8. Thanks GoDadGo thanked for this post
  9. #5
    Rotonda West Florida
  10. Thanks GoDadGo thanked for this post
  11. #6
    I didn't care for a few items on Shelby's car which were the mirrors and J-style roll bar, but my car will be red with no stripes, no hood scoop and sporting some wheels we picked in an attempt to emulate the sunburst style rims. Also like CSX-3178 our car will have stainless side pipes and bumpers front and rear.
    Unlike that car, my drive-train is all wrong by comparison but I love that somewhat street look, the color, black roll bar color, stainless treatment for the bumpers and side pipes.
    Shelby CSX 3178 Pics:
    Shelby CSX 3178 Sells:
    https://youtu.be/FJpASOjJWa8
    Factory Five #8,515 From The Dark Side:
    https://youtu.be/wOID7yvBRPU
    I'm just not sure about what style mirrors I'll end up with and please know that this car is more of the "Flavor of CSX 3178" and not a true clone.
    Hope This Makes Sense & Thanks For The Post!
  12. #7
    I never comment on matters of taste, but since you asked... I don't love them.
  13. Thanks GoDadGo thanked for this post
  14. #8
    Mar 2013
    Medway, MA
    A decent alternative mirror that looks a little like it belongs on a hot rod.
    The best for the roadster is clearly
    https://www.breezeautomotive.com/sho...m-made-in-usa/
  15. #9
    Quote Originally Posted by Mark Reynolds View Post
    Mark,
    I've got your seat mounts, fan shroud and your side pipe wedges so you know that your products are always on my radar.
    Still not sure what I want on the car for the side view mirrors, but I need to decide sooner than later.
    Thanks For The Great Service By The Way!
    mburger's Avatar
    Punta Gorda FL
    Breeze mirrors work great on my roadster.
    Mark
  17. Thanks GoDadGo thanked for this post
  18. #11
    Nov 2012
    Tacoma, WA
    I say no just don't look right on a Cobra. Its like taking a Chevy part and putting it on a Ford, that's just not right. Of course Steve you may have first hand experience with that. LOL
  19. Thanks GoDadGo thanked for this post
  20. #12
    Jax Beach, FL
    I am in the camp that while they are nice looking mirrors, they will look wrong on a Cobra.
    Short version of the usual rant:
    If you see your fenders in your mirrors, you have them adjusted incorrectly. (See long version of rant elsewhere on how to adjust them in all your cars) Turn your head and look before a lane change. You know, like every states drivers manual says to do. Do those two things, and bullets, or even just one bullet, works fine.
  21. Thanks GoDadGo thanked for this post
  22. #13
    Quote Originally Posted by Paul2STL View Post
    I've Got Mopar Super Bee / Road Runner 383 Hood Emblems To Confuse You Ford Fellows!
    https://www.summitracing.com/parts/amd-999-1469-31
    They'll be mounted above the fender louvers and hold those side slats in place.
  23. Likes Mark Reynolds liked this post
  24. #14
    Copperhill, TN
    I started with the bullets, which were fine until I added the top, which made lane changes in traffic a bit too exciting for me. I added the Breeze mirrors, huge improvement and I highly recommend them.
    As to your initial question, I don’t think the first ones would look right on a cobra, but that is of course just my opinion.
  25. Thanks GoDadGo thanked for this post
  26. #15
    Mar 2013
    Medway, MA
    Speaking of odd parts combos - Been thinking about a rectangular/oval exahust tip for my son's Volvo 850 Wagon and the tip from a 1970 383 GTX comes to mind!
  27. Thanks GoDadGo thanked for this post
  28. #16
    Here Are All The Oddities For You Mr. Mark:
    1. 383 Small Block Dart 10-1 Somewhat Pump Gas Friendly Compression Ratio!
    2. Eagle Internally Balanced Rotating Assembly With 6" H-Beam Rods With Floating Forged Flat Tops.
    3. Dart Iron Eagle 215 CC Heads with 2.05 Intake & 1.60 Exhaust Valves.
    4. Harland Sharp Roller Rockers & Other Go Fast Goodies.
    5. Comp Cam Extreme Energy 288 Hydraulic Roller Tappet Cam
    6. Edelbrock AVS 800 Feeding A Weiand 7530 Team-G Single Plane Manifold.
    7. Schoenfeld IMCA Modified Headers & They Really, Really Fit, But Stuff Had To Move A Bit!
    8. New Old Stock Corvette ZF 6-Speed Transmission With Hydraulic Clutch. (.75 5th & .50 6th Gear Over Drives)
    9. Standard Front End Set Up With Mustang Brakes & Forte’s .75” Sway Bar.
    10. Standard 3 Link Moser TSD 500 (Dana 44) Rear With 3.73 Gears & Explorer Brakes.
    11. The wheelbase has been shortened by .875" to better center the rear wheels within the wheel arches and improve pinion angle adjustment.
    Now If I Can Only Figure Out What Mirrors The Perseverance Build Will Wear Then All Will Be Right With The World!
  29. #17
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    I would strongly consider installing windwings and then go with a stainless steel windwing clip- on mirror from Speedway Motors, Part#91133003.
    I have on one my '33 and it is very neat and easy to mount, and works well too.
  30. Thanks GoDadGo thanked for this post
  31. #18
    Style wise, I will let you decide if you like them. But Mr Kliener is 100% on how effective they may be.
  32. #19
    Senior Member RickP's Avatar
    Boyertown, PA
    Steve - you cant go wrong with the mirrors that Breeze offers. A little pricey but you get what you pay for. They do not transfer any vibrations and stay put. I agree with Jeff K the mirrors you are contemplating when mounted will shake like the dickens.
    RickP
  33. Thanks GoDadGo thanked for this post
  34. #20
    riebelt's Avatar
    Steve, I can not apologize for the labor involved to produce quality. I have a set waiting for you here. You will love them. If not, I have no problem with you returning them.
  35. #21
    riebelt's Avatar
    Steve, To follow up with your original request concerning opinions of the mirror examples you posted. You need to consider the fact that when mounting those you will still be looking through the wing material. That in itself presents an issue in that you will find yourself sort of hunting or focusing to look into the mirror. The Plexiglas material will cause this. Any mirror you place on the opposite side of the Plexiglas will do this. Even the Raydots. I have had many BackDraft owners want to change as a result of this. As far as the PEEPS... well, that is an alternative. Check the mounting. That clamps to your windshield post. Just so you know, the peep was my last choice before I developed the wing mirrors. The mounting would stretch and I would need to keep snugging up the set screws. The moving around scratched the hell out of my windshield post. After that, I refused to re-install them. I still have that set of peeps laying in my basement gathering dust. I've been meaning to throw them in the trash. So keep that in mind as well. I'm not trying to push my product that you can get from Mark or myself. It's more about just trying to get you to think through some options before pulling the trigger on something you may ultimately not be pleased with.
  36. #22
    Quote Originally Posted by riebelt View Post
    I'll probably stick the Wind Wings on and play with the bullet mirrors before I do anything. I just never liked anything that takes away from the body lines and may blow off the side views all together. I'm in Louisiana so the Thought Police & Nanny State isn't as bad as in most places so not having side views isn't a big deal.
    Heck, I've even taken a few Law Enforcement Fellows for rides very recently.
  37. #23
    riebelt's Avatar
    You are doing this before paint correct? That was part of my point in that you "can't put the bullet back in the gun", so to speak.
  38. #24
    +1 for Terry's mirrors! I haven't installed mine yet, but the quality is fantastic. And, for those that are blacking out their trim, they are available in a black anodized finish.
    Black: https://www.breezeautomotive.com/sho...odized-finish/
    Polished: https://www.breezeautomotive.com/sho...m-made-in-usa/
  39. #25
    Just to muddy the waters...I have at least 3 of the bullet mirrors. They may all be alike or maybe not but I'll be happy to send one so that you can make a matched pair.
    I'll send you pics tomorrow of what I have.
    Thanks!
  41. #27
    Aug 2011
    San Jose, CA
    One more vote for the Breeze mirrors. I tried a couple different mirrors before finding them. They blend in nicely into the side wings and they are stable. Some of the other mirrors would shake so much that I though there were 3 cars to my left. When I fist started driving my Cobra, I really liked the look of no side wings or sun visor. After a month of driving around, it got old. I am still amazed that two little pieces of plastic make such a difference.
  42. Thanks GoDadGo thanked for this post
  43. #28
    UPDATE:...Factory Five Family Member Racee75 is getting the one mirror so I still have the another on hand.
    The price is simply the cost of shipping.
  44. #29
    B-B-Bump!
    I've got one mirror left, which is the long stem version.
    The cost to you is the cost of shipping.
    Send me a PM if you are interested.
    The first message gets the piece.
  45. #30
  46. #31
    On a roll Al_C's Avatar
    Wheaton, IL
    Disclaimer: I'm a little late to this particular party and I didn't read (in detail) all the comments. That said, here are my comments: GoDad, you already put a Chevy in a Cobra. Do whatever your heart desires.
  47. #32
    Doing my own thing really is the theme of my build for sure!
  48. #33
    Yeah, we've noticed!
