Thread: Any Ideas for a Throttle Pedal for Cable operated Throttle body?
    I'm working on a GTM for a customer who just purchased a stand-alone EFI system that has no provisions for the throttle-by-wire.....it has a cable operated throttle body. Anyone here familiar with a throttle pedal that is similar in shape/size/construction to the 'Vette throttle pedal, but cable operated?.....so it might mount in the same basic way and end up in the same basic position as the Vette pedal?
    Shane Vacek
    www.vraptorspeedworks.com
    Ottawa Ontario
    Lokar has a good selection. Have used them in hot rods and F bodies which mount on a standoff. Scott
    http://www.lokar.com/direct-fit-throt-assemb.html
    Senior Member beeman's Avatar
    Indiana
    I used a Russ Thompson (site donor) pedal in my roadster, you could see if he'd loan you one to test fit. It's designed to clamp to the roadster frame but looks easy to modify.
    http://www.norcal-cobras.com/store/r...k3/mk3ftp.html
    GTM #304 LPE 525hp LS3
    Thanks, guys! I'm on bodywork duty for a while and probably won't tackle this project until the bodywork is done and I pull the body off the chassis, so it will be a while.
    Shane Vacek
    The last LS that used a throttle cable were the 6 speed Z/28's and Trans Am's from the 4th generation that ended in 2002.
    You can find one on Ebay pretty easily.
    Also, a gas pedal assembly from a 3rd generation Camaro or Firebird or C-4 Corvette are also possible options.
    Hope this helps and if it doesn't sorry for cluttering up your thread.
    You're definitely not cluttering up my thread!!....this is just the sort of stuff I'm looking for!!
    Shane Vacek
    Nov 2018
    Try these guys, they should be able to make a cable specifically for your needs:
    https://www.motionpro.com/
    They specialize in motorcycles, but as far as I know they can make any throttle cable you need.
    Maricopa AZ
    We just did one in a twin turbo car we are doing. Locar pedal and 120" cable
    Quote Originally Posted by Gordon Levy View Post
    Thanks!! Do you know which part # Lokar pedal you ended up using?
    Shane Vacek
