Fuel Safe Systems
Results 1 to 7 of 7
Thread: WTB: 700R4 shift linkage
    Jan 2019
    Sandy Hook, Virginia
    I'm getting a motor/trans from Factory Five Blue Print Engines with a 700R4. It doesn't come with the shift linkage. I'm looking for the linkage to fit or one from a late model Camaro, Trans Am or Fire Bird.
    Dec 2017
    Lokar makes a good setup for the 700r4. Also upgraded the kick down cable and throttle cable to lokar. So far have it mocked up on transmissions. Hoping to install motor and tranny after I get back from Mexico
    Mar 2018
    Yucaipa, CA
    I did a 52' Chevy pick up sometime back with SBC and 700r4 trans. I also used all the lokar cables and shifter and had no problem with any of it. Worked as advertised.
    Senior Member TDSapp's Avatar
    Frisco, TX
    I am running a 700R4 out of an 89 Corvette and also used the Lokar shifter. It has hard linkage to it and does not use any cables.
    Here is a link to the post on my build site showing how I installed it.
    http://hotrod.sapp-family.com/2018/0...ifter-is-done/
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Dec 2018
    I used one from shiftworks.com on a build I did with a 4L60E they are very similar.
    Jan 2019
    Thank you for all your experiences. I have been to a few junk yards and decided to ditch that idea. I looked and liked the Lokar but also a B&M from Summet. My ship date is 3/23 so I have a while to make the final decision. This looks like it's going to be a great experience.
    Heart of Dixie, Alabama
    B&M will not compare to Lokar.
  8. Likes Houdini liked this post
Levy Racing
