Thanks Thanks:  44
Likes Likes:  132
Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
Results 521 to 560 of 710
Thread: Patrick's 427 Build
  1. #521
    Senior Member Pat427's Avatar
    New Braunfels, TX
    Hood Latch Mod
    I completed the hood latch modification. I gotta say that I'm glad I did this one. The final product is a much more solid feeling latch, plus it looks cleaner too.
    I had to re-orient the hood latch holes in the transverse lie, instead of front to back. I then mounted the flat 10-32 plates onto the underside of the upper hood layer using HSFR. I held the plates in place with one of my nutserts while the HSFR hardened.
    Then I grinded the bushings and mounted them into the underside of the hood with HSFR.
    I then grinded the square bar a little bit so it would fit through the bushing.
    I then re-mounted the latches using 1/2 in 10-32 screws.
    I'm pleased with the finished product.
    I also received my crimpers for the Weatherpacks. That'll be my project tomorrow. In the meantime, it's off to work for an overnight shift.
    MK4-IRS, 427w, TKO-600
  2. #522
    New Braunfels, TX
    Throttle Mount
    I broke down and finally purchased a throttle cable plate from FAST. I just wasn't happy with the way the existing throttle connection looked.
    I had to grind the base plate a little bit (red arrow) because it was interfering with the coil. I then spray painted the area to cover up the grinder marks.
    The cable is much straighter and looks cleaner.
    Question: Is there a better way to connect the cable to that L-brakcet (blue arrow)? I'm worried that the only thing connecting the cable to the throttle is a little set screw.
  3. #523
    Pat,
    Ask and we'll help you spend a bit more of your money. This connector from Lokar is a great choice to replace the one from the kit that your are using:
    A cheaper option is to run a second set screw in the kit-provided connector so that you pinch the cable between two set screws.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  4. #524
    New Braunfels, TX
    Dave,
    You've become a really good spender of my money during the build. . I've seen this connector in other build threads and I like it. Thanks for the link.
    Pat,
  5. #525
    Heart of Dixie, Alabama
    Neat looking set up, but I think you can do better with those throttle return springs.
    They should be in line with the travel of the throttle shaft bracket. Ideally they should pull opposite of the travel. I see a couple of places to hook them, that would not require much work. JMO
  6. #526
    New Braunfels, TX
    Wiring Question
    I'm trying to get my lights wired today, however I've hit a wall.
    Coming out of the Dash Harness are three wires (see pic)
    There is a light blue wire called HDLT SW-DIM, red LOW BEAM and a brown wire HIGH BEAM.
    Where do these go?
    According to the wiring diagram, these are supposed to connect to the Front Harness, but I don't see how that is possible. It seems to me they need to connect to the Headlight Switch, but my headlight switch only has two free male connections.
    Any help would be appreciated
  7. #527
    Quote Originally Posted by Pat427 View Post
    Wiring Question
    Where do these go?
    Pat,
    Here is how they go on the kit-provided switch (On-On switch):
    I ended up using a relay wired like this:
    With is setup, if the switch fails, I still have low-beams by default.
    Legal: 1/30/2020
  8. Thanks Pat427 thanked for this post
  9. #528
    New Braunfels, TX
    Dave,
    Thank you for the picture. I was totally off with my thinking. I was able to get the lights working properly. Very happy to see the lights on for the first time.
    Pat,
  10. #529
    New Braunfels, TX
    Weatherpacks
    I started working on my Weatherpacks today. After watching a Youtube video I went to work. I was able to get them put together without too much fuss. The proper crimper makes all the difference.
    I noticed the RF Front Harness only has one ground wire for the passenger side and one ground wire for the drivers side, but there are two lights (Headlight and Turn Signal) on each side of the car that both need a Ground wire. Therefore, I'm missing one ground wire on each side.
    So, I decided to connect the Ground wire to the frame. I drilled a hole and installed a 10-32 nutsert into the frame.
    From that point, I'll be able to run two ground wires: one to the headlight and one to the turn signal light.
    Then I hooked up the Weatherpacks to the headlights.
  11. #530
    New Braunfels, TX
    Turn Signal
    On the front passenger turn signal lights:
    On the RF harness, there is a Tan, Light Blue and Black.
    On the Turn Signal, there is a Yellow&Red wire and a Green wire.
    Does anyone know the mating pattern with these wires?
    Much thanks,
    Patrick
  12. #531
    In the rear:
    The Ron Francis harness is set up so that all 4 lamps are illuminated for tail lights with one on each side used for brake lights and the other on each side used for turn signals. I prefer to orient them so that the uppers are brake lights for better visibility. When using that configuration:
    ---Tan harness wire at each corner is for tail lights and will go to the low element on all four light assemblies via the red/yellow lamp wire.
    ---Purple harness wire at each corner is for brake lights and will go to the bright element on the upper light assembly per side via the green lamp wire.
    ---Yellow harness wire on the driver's side is for left turn and goes to the bright element on the lower light assembly via the green lamp wire.
    ---White harness wire on the passenger side is for right turn and goes to the bright element on the lower light assembly via the green lamp wire.
    ---Black wire on all joins with the black harness ground.
    In front:
    ---Tan harness wire at each corner is for the amber parking/running lights and will go to the low element on both light assemblies via the red/yellow lamp wire.
    ---Dark green harness wire on the driver's side is for left turn and goes to the bright element on the light assembly via the green lamp wire.
    ---Light blue harness wire on the passenger side is for right turn and goes to the bright element on the light assembly via the green lamp wire.
    ---Black wire on both joins with the black harness ground.
    Legal: 1/30/2020
  13. #532
    New Braunfels, TX
    Awesome! Thanks Papa!
    In the rear:
    In front:
  14. #533
    New Braunfels, TX
    Lights
    I was able to get the headlights and turn signal lights to turn on, but the turn signal doesn't work when I toggle the turn signal switch. Below is a picture of the lights on. The other picture is the turn signal switch wiring.
    Could the switch be bad?
    Pat
  15. #534
    Dublin, OH
    Is ignition keyed on? I think the power supply for the turn signals only work with key on as opposed to the hazards, which have constant power with key off (pink wire)
  16. #535
    New Braunfels, TX
    egchewy79,
    Thank you for the advice. I turned the key to the "On" position and then tried the turn signals again. This time, both turn signal lights blink like what I would expect the Hazard lights to do. I guess I've got something mixed up.
  17. #536
    Pat,
    On the hazard switch, run the two red wires to the two center pins on the 6 pin switch. Then, put both the left and right wires on the two pins on just one end of the switch. It doesn't matter which end or which order the wires are placed. The pins on the other end of the switch will not have anything connected to them.
    Legal: 1/30/2020
  18. #537
    New Braunfels, TX
    Hazard Switch
    Does this look correct?
    I'm concerned because the light blue and green wires say they are Front Turn wires. It doesn't seem like those wires should be on a Hazard switch?
  19. #538
    That is correct. The 4 way hazards power the wires for LF and RF turn signals as well as the LR and RR turn signals. The LF and LR tie together downstream in the harness as do the RF and RR.
    New Braunfels, TX
    Wiring Continues
    Alright, so I've made some progress, but things still seem mixed up.
    When I toggle the Hazard switch to the "On" position (just like in the picture above), the turn signal lights will work properly. However, if I toggle the Hazard switch to the, "Off" position, the turn signal lights will both blink.
  21. #540
    New Braunfels, TX
    Brake Switch
    Ok, so here's the current situation with the wiring:
    The rear lights will only turn on if I also turn on the headlights. Once I pull the headlight handle out one notch, the rear lights of the car will light up. At that point, the turn signal will also work. However, if I turn off the headlights, the rear lights turn off, turn signal doesn't work and the brake lights won't turn on when the brake pedal is pushed.
    I'm mostly concerned the brake lights don't work when the brake is pushed. I took a picture of my Brake Switch: Does this look right?
    The white plunger on the Brake Switch is being pressed when the pedal is at rest. Once I press the pedal, the pedal is pushed away from the Brake Switch plunger and the plunger extends. Is this correct?
  22. #541
    Pat,
    Two things for you to consider:
    1. For the turn signals to work, they all have to be hooked up. It sounds like you have then connected, but just want to be sure.
    2. A bad ground connection in either side of the Weatherpack connector can cause weird results. Check the harness side of the connector with a volt meter to see if you are getting power on each of the tan, purple, yellow, and white pins with the ground pins in the connectors. If all those check out, use an ohm meter to do a continuity test on the lamp side connectors using the pins in the connector. If those check out, you have good connections and should work.
    The brake light switch looks correct, but check the harness as described above with a helper or by wedging the brake pedal. There is an error in my version of the manual and I had to move the wires to the other two spades on the switch as my brake lights were on with the pedal at rest and would turn off when the pedal was pressed. Also, make sure the plunger comes out far enough to actuate the switch or the lights will never come on.
    Legal: 1/30/2020
  23. #542
    New Braunfels, TX
    Thanks for the response, Dave.
    I was able to get all the lights on the car working properly except for the brake lights, I still haven't figured them out yet. The brake lights WILL light up, but only if I pull on the knob on the headlight switch. So, it seems like the wiring and grounds are good to those lamps. Without much knowledge on the subject, I'm convinced the issue is with the brake switch. I'm gonna mess with that today and see if I can make any progress.
    Pat,
  24. #543
    Your brake light switch should have a hot at all times lead, if you want the brake lights to work with the key off and headlight switch off.
    The other wire(s) should go to the bright filament on the upper bulb on the rear of the car.
  25. #544
    New Braunfels, TX
    Functionally Complete
    After getting advice from the forum, I ended up replacing one of the fuses in the fusebox and BAM! The brake lights are working as intended. I'm very excited about this because now the car is functionally complete.
    All systems are currently working: lights, gauges, engine, fan, brakes, transmission, horn, wiper motor. This is a pretty big day for me. Obviously, I have a lot of work until the car is totally complete, but I'm feeling good at the moment. Obviously, I would never have been able to get to this point without the help of BadAsp427, Papa, EdwardB, TMartinLVNV, Skidd, Kleiner, Wareaglescott, Boydster, Railroad, Mark Eaton, among multiple others. Thank you all for your help!
    I'll keep you guys posted.
  26. Likes Boydster, PeteMeindl liked this post
  27. #545
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Grab an ice cold beer and savor it while looking at your accomplishments in your garage.
  28. Likes Pat427 liked this post
  29. #546
    New Braunfels, TX
    The Build Goes On
    Not much to report today. I started on the modifications to the door handles. I was only able to work on where the knob attaches to the lever. According to other builders, the little knob can wiggle loose and fall off the lever. The recommendation is to drill and tap a 10-32 hole into the knob, which is what I did. Not too difficult and I was able to complete this with minimal fuss.
  30. #547
    New Braunfels, TX
    Chipping Away
    I'm still chipping away at the remainder of the build. Work has been crazy recently, so not a ton of time to dedicate to the garage. I received my Lokar throttle linkage today and was able to get it installed. Pretty straightforward. Looks and feels much better than the kit supplied part.
  31. #548
    Looks good Pat. In the FAST bracket kit, you should have a couple of other pieces that came with it that will allow you to bring those return springs over a bit and not have them at such a sharp angle. That's what that unused slot is beside the one where you attached the throttle cable.
    Legal: 1/30/2020
  32. #549
    New Braunfels, TX
    Ahh, I see it now. Yes, There are other brackets in the FAST box. I'll use one of those extra pieces and then I will be able to hook the springs in a better way.
  33. #550
    New Braunfels, TX
    Spring Fix
    I used an extra throttle mounting tab that came with the FAST kit and attached it to the underside of the base plate and was then able to hook the springs more parallel with the throttle cable.
    I'm not entirely sure if this makes a functional difference, but it certainly looks more clean.
    With the help of my wife pushing on the brake pedal, I was also able to get my front CV nut torqued to 250ft/lbs. I still have to torque the rears. That'll be on the list of things to do tomorrow.
  34. #551
    That looks great, Pat. I may have to go fix mine now.
    Legal: 1/30/2020
  35. Thanks Pat427 thanked for this post
  36. #552
    Good job, looks clean!
  37. Thanks Pat427 thanked for this post
  38. #553
    New Braunfels, TX
    Body
    I put the body back on today. I'm going to have to move it forward about an inch or so. However, that will have to wait for another day since today is our anniversary and the wife will kill me if I spent the whole day in the garage.
  39. #554
    Happy anniversary, Pat!
    Legal: 1/30/2020
  40. Thanks Pat427 thanked for this post
  41. #555
    New Braunfels, TX
    C'mon Georgie
    I'm once again in a holding pattern. I ordered Gas'n Side Pipes about 2 months ago and they still have not arrived due to the fact that Gas'N is shut down by this quarantine.
    I called Georgie from Gas'N a few weeks ago and he didn't really give me a timeframe due to the uncertainty of the lockdown. Annoying, but understandable.
    In the meantime, I'm trying to get as much done as possible. I'm going to tackle the windshield this weekend. I have the needed tap to make the modification that EdwardB mentioned in his thread.
    I'll keep ya'll posted.
  42. #556
    New Braunfels, TX
    Trans Cover
    I finally buttoned up the transmission tunnel cover today. This was more of a P.I.T.A than I had anticipated. Basically, after I put the heat shield and carpet in the cockpit and leather on the tunnel cover, it wouldn't fit very well. I ended up having to drill and tap 1/4-20 holes in order to get the cover to get secured properly.
    In the front, I put the bolts on the sides of the cover and in the rear, I put them on top. I'll probably replace those ones with black bolts later on. I wasn't pleased with this at first, but it started to grow on me after a while.
  43. #557
    Jun 2019
    Las Vegas, NV
    I love the cover. Good job. The silver bolt heads are not bad, but black chrome would probably look a little cleaner.
  44. #558
    New Braunfels, TX
    Thanks Terry. I agree with you.
    Quote Originally Posted by TMartinLVNV View Post
  45. #559
    Apr 2019
    NC
    You could hide them with screw caps...https://www.autoattire.com/license-p...ap-covers.html
  46. Likes Pat427 liked this post
  47. #560
    New Braunfels, TX
    Quick Jacks
    I mocked up the Quick Jacks today.
    I think I'm going to end up putting on chrome overriders instead of the quickjacks, but for now, this will have to do. The ends of the threaded rods are still ugly, but I'll clean those up eventually.
    Anyone with recommendations for where I can get good chrome overriders?
    Pat
