Thanks Thanks:  44
Likes Likes:  132
Page 11 of 18 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 710
Thread: Patrick's 427 Build
  1. #401
    Senior Member Pat427's Avatar
    New Braunfels, TX
    Clutch Adjuster
    Not much to report today. I installed my clutch adjuster today. Went together fairly easily. I drilled and tapped 10-24 holes in the footbox and then screwed on the adjuster. I ended up dinging up the footbox aluminum panel getting the old clutch adjuster out. I'll touch up the powder coat later with some matte paint.
    MK4-IRS, 427w, TKO-600
  2. #402
    New Braunfels, TX
    A Little More Progress
    I made a little more progress today.
    First, I was able to install the windshield wiper wheel box mounts. This was fairly painless. It was a little awkward to drill that oblong hole, but was able to make it work using my Dremel.
    Next, I was able to test fit my new shifter. A big thank you to Papa for sending me the longer bolts needed to mount the shifter. I'm happy to report that the issue with interference with the trans tunnel cover has been fixed with this new handle.
  3. #403
    New Braunfels, TX
    Windshield Wiper Wiring Question
    Probably a silly question, but I thought I'd run it past the forum to be sure.
    In the diagram for the windshield wiper wiring, there is a picture that shows two wires (purple & white) docking to the same location on the wire motor.
    In order to accomplish this, do I simply twist those two wires together and then insert them into one of the provided connectors as seen below?
    Patrick
  4. #404
    That's what I did.
  5. Thanks Pat427 thanked for this post
  6. #405
    New Braunfels, TX
    Wiper Wiring
    Not much to report today. I finished the windshield wiper wiring today. It was pretty simple. Not sure where I'm going to mount the switch. I haven't decided if I'm going to put it on the dashboard or mount it under the dash.
    Also, I received the 6AN hose that I'll be using to build my new fuel lines. Hopefully the 6AN hose will satisfy the Holley Sniper which requires 3/8th lines. Still waiting on the 6AN fittings to get delivered before I can start that project.
  7. #406
    New Braunfels, TX
    Fuel Line Issue
    For a recap, I've decided to replace my fuel lines with 3/8th in. (send and return) lines in order to satisfy the demand of the Holley Sniper and my 427 engine. I've decided to run flexible lines this time.
    I purchased 6AN PTFE lined fuel hose and now I'm piecing together the fittings needed to make all the connections.
    I received most of these fittings today, but realized I didn't purchase the PTFE appropriate fittings, so I'm returning them today and re-ordering the correct ones (the ones with the little olive).
    But, I discovered another issue and I'm hoping the forum can clear this up for me.
    My issue is with the fuel send line that connects to my fuel filter. My engine came with a fuel filter already installed. See pic below.
    Another shot looking up at the filter:
    The male end is 3/8th, so I ordered this piece in order to connect the filter to the hose. It's a 3/8th to 6AN piece.
    However, I can't get the plastic retaining piece to fit over the male end of the fuel filter. The little collar on the fuel filter is too big and won't allow the blue plastic clip to fit onto the male end.
    Does anyone have any advice on how to connect the 6AN fuel hose to this end of the fuel filter?
    Pat
  8. #407
    Apr 2019
    NC
    Non-compatible fitting for the filter. Could use a 6AN to barb fitting or change out filter.
    Also not sure why they have the fuel line routed that way either. Should be able to relocate to inlet port #1 on back of throttle body.
    Do you have the regulator mounted to the firewall?
    Here is old post when you mounted it https://Post #148
    Not needed, Sniper has it's own internal fuel regulator.
    You installed a new pump hanger, the sock on that hanger is the first filter, you can eliminate one of your inline filters and install the 10 micron inline.
  9. #408
    New Braunfels, TX
    Greg,
    I previously removed the regulator on the firewall since the Sniper has its own.
    My engine builder already has the fuel line going from the other side of the filter to Port #2.
    The reason I would like to use the existing fuel filter is because in order to remove the filter, I would have remove my power steering pump in order to access the AN fittings on the outlet side of the filter.
    So, ideally, I'd like to figure out a way to attach my 6AN fuel hose to the male barb on the filter. You mentioned a 6AN barb fitting. Is this what I would need? https://www.amazon.com/Derale-98204-.../dp/B004XOR9T4. It seems like a piece like this would require a plain piece of tube to connect to the barb on the filter?
    Quote Originally Posted by Greg K View Post
  10. #409
    Apr 2019
    NC
    Can you not disconnect the line up top at the throttle body and pull it down? You don't need to three filters and the additional fuel line around and under the engine and can eliminate the barb connection.
  11. #410
    New Braunfels, TX
    Greg,
    For clarification, I have already bypassed the fuel filter that came with the kit.
    So as it stands, the fuel goes through the filter that is on the bottom of the in-tank hanger and then goes to the filter that my engine builder already installed (1st picture in post #406). From that filter it goes to the Sniper.
    I could disconnect that fuel line from the Sniper, but the other end of the line is still connected to filter outflow port. I would have to remove my power steering pump in order to reach the AN fittings and loosen it, which I really don't want to do.
    I would prefer to leave the filter in place and get that 6AN fuel line to go through the filter. I just have to figure out a way to get the 6AN fittings to attach to the male in-flow port on the filter.
  12. #411
    Senior Member cv2065's Avatar
    I think you'd have to use the barb fitting and connect with a rubber hose and clamps. Personally. I would change out the filter to one that works with braided AN fittings. A little more work, but that's with just about everything.
  13. #412
    Apr 2019
    NC
    Thought you still had the filter back by the tank. Do they have some bracket or clamp holding the fuel filter or fuel line in place behind the PS pump?
    Could always put the filter back in that came with kit, you have all the lines for it from the tank. IMO, it would be a much cleaner and serviceable install in the end.
    Quote Originally Posted by Pat427 View Post
    Greg,
  14. #413
    New Braunfels, TX
    Greg,
    The filter is bolted to the engine block by a hose clamp. It would be impossible to get a wrench on that bolt and the AN fitting that holds the fuel line to the out flow side of the filter with the power steering pump still in place.
  15. #414
    Apr 2019
    NC
    What's another hour or two...your call, I know what I'd do.
  16. #415
    BadAsp427's Avatar
    Greeneville, TN
    Pat,
    Just my opinion. The filter you engine builder put in will some day have to be removed to replace it with a new filter, right? If that is the case and it is that hard to get too now then I would suggest moving it now so that in the future, with a completed car, painted, etc you are able to replace it with ease. The mounting location that the manual shows back in the rear of the car makes the replacement much easier.
    Also, the fitting that is on the current filter that your engine builder gave you is designed for a simple rubber hose and hose clamp be attached to it. There are end pieces that are designed to "hide" the hose clamp and give the appearance of the actual hose fittings. This photo is an example of that type of fitting (just a bit larger).
    Again, however, I would find a place to install your filter that is much easier to get to and replace when the time comes that you need to replace it from normal use. Just because your engine builder put it there does not mean it is the best for your build.
    Hope my opinion helps...
    Carl
  17. Thanks Pat427 thanked for this post
  18. #416
    New Braunfels, TX
    Carl,
    As always, your advice much appreciated and I'll be taking you up on finding a more easily accessible location for my filter for all the reasons you mentioned.
    Pat,
    Carl
  19. #417
    New Braunfels, TX
    Wiper Support
    I originally saw this modification in EdwardBs thread, but have seen several others do the same. I took a piece of 3/4in tubing and cut new supports for the windshield wiper wheelboxes. These metal support replace the rubber ones that came with the wiper kit. Fairly simple project and I'm pleased with the results.
  20. #418
    New Braunfels, TX
    Fuel Line Routing
    With respect to the flexible PTFE fuel hose, is it okay to route the hose on top of the engine manifold or is this a no-no?
    For example, in this picture, would it be okay to route the hose where the red arrow is pointing?
  21. #419
    Apr 2019
    NC
    Why not cut it shorter and use port #1 on the rear? Just swap the fittings on the throttle body.
  22. Thanks Pat427 thanked for this post
  23. #420
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    I second that. The inlet and outlet on the back of the TB should be used. No need for a fuel line to have to be routed to the front.
  24. Thanks Pat427 thanked for this post
  25. #421
    Definitely swap to the rear input -- much cleaner.
  26. #422
    New Braunfels, TX
    Roger that.
    Thanks for the advice guys.
  27. #423
    With everything you've done and been through, I really am looking forward to seeing this car run and done. Especially when I look back to your first post... "I have no knowledge or experience when it comes to building a car." Yer gettin it done!
  28. Thanks Pat427 thanked for this post
    Likes Papa liked this post
  29. #424
    New Braunfels, TX
    Thanks Boydster! I've definitely learned a lot over this past year. This forum has helped more than I ever imagined. I think I'm getting close to being able to wrap up the build soon. I'm looking forward to seeing it done too.
  30. Likes Papa liked this post
  31. #425
    New Braunfels, TX
    Holding Pattern
    Still waiting for my PTFE hose fittings to arrive in the mail, so I'm kind of in a holding pattern today. I decided to mock up my cockpit today just for fun.
  32. Likes Boydster liked this post
  33. #426
    New Braunfels, TX
    Warning?
    As outlined in a previous post, I installed the Pro-M Racing Fuel Pump Hanger.
    I installed the hanger without too much hassle. It required that I grind the opening of the fuel tank a little but, which was fairly straightforward. Of note, I did this modification/installation with 1/4 tank of gas in the tank.
    I saw this warning on the Installation Instructions and ignored it, but now I'm getting ready to start my engine again and I'm growing scared and wanted to run this past the forum.
    I did not, "thoroughly clean" the tank before installation of the hanger. Again, I installed the hanger with fuel still in the tank, so there was no cleaning to be had. I'm not sure if I needed to drain the tank and clean it or what. I'm not sure what/how a fire or explosion would happen, but I was hoping someone could shed some light on this?
    Thank you guys,
    Patrick
  34. #427
    Apr 2019
    NC
    Grinding on the tank may have caused a spark to ignite any fuel that may be in the tank. Nothing to do with attempting to start engine once more.
  35. Likes Pat427 liked this post
  36. #428
    I did not have to grind my tank. The Pro M lines will flex enough to go in, without damage or grinding.
    Watch the wires on the sharp metal edges.
  37. #429
    New Braunfels, TX
    Railroad,
    You read my mind.
    I too was a little worried about the wires getting damaged by the sharp edges. My paranoia got the best of me, so I decided to check it out. I removed the fuel filler and took a picture. I poked the wires around with a chopstick to make sure there were not any exposures or damage. Things looked okay. Pic below.
  38. #430
    Jun 2019
    Las Vegas, NV
    That's how I did mine too. It was tricky, but no modifications were necessary.
  39. #431
    Jun 2019
    Las Vegas, NV
    Railroad,
    You read my mind.
    It is looking good Pat. You will be happy that you went with the bigger lines and hanger when it is all finished up.
  40. Thanks Pat427 thanked for this post
  41. #432
    Railroad,
    You read my mind.
    Looks good, Pat. Good decision to do the proper lines now. What did you end up doing for the filter? I have a nice Holley filter with -6AN inlet and outlet and some mounting rings that I didn't use if you are interested. Not cheap, but top-shelf and I'll save you some money over retail.
  42. #433
    New Braunfels, TX
    Dave,
    As of now, I ended up using the existing filter that came with the kit. It was already in place, so I just used it. I considered using an aftermarket Holley filter, but I’m not sure if it’s needed.
    Is there a specific advantage to using an aftermarket Holley filter?
  43. #434
    Dave,
    No specific advantage I can think of as long as it can be easily replaced and keeps the crud out of the injectors or jets.
  44. #435
    Feb 2020
    15 miles north of Spokane, Wa.
    Pat:
    Thanks for your build information. You are a year ahead of me. I'm just doing the suspension and I already had several of the issues you raised. You are going to save me a lot of head scratching. I've only read your first two pages and skipped to the end to thank you. I'm looking forward to how you dealt with the issues I'm sure are upcoming for me. Also, thanks to everyone who has helped you, they are also helping me.
    One question, what is the trick you used to spread mounting brackets that are too tight? So far I've used a 24 inch Crescent wrench. Maybe you have a better technique.
  45. #436
    Quote Originally Posted by SteveP View Post
    Get a piece of threaded rod, a pair of nuts, and a pair of washers. put the nuts on the rod and thread them toward the center of the rod. slip the rod between the tabs with the rod running through the tab's bolt holes. slip a washer larger than the tab's holes onto the rod inside the tabs on both ends. spin the nuts back out toward the ends of the rod until they are holding the washers against the inside of the tabs. continue to wrench on the nuts until the tabs are spread apart to the desired width. If you need to pull the tabs closer together, just put the nuts and washers on the outside of the tabs instead of the inside.
  46. #437
    Feb 2020
    Thank you. A much more elegant solution than bending the flange with my 24 inch crescent wrench.
  47. Likes Pat427 liked this post
  48. #438
    New Braunfels, TX
    Unhappy Camper
    I had planned on tightening up all my fuel line connections today and attempt to start my engine, but I ran into a snag.
    I had assembled a short piece of fuel line to connect my new Pro-M Hanger to the fuel filter. Well, when I was tightening the fitting onto the hanger, the dang fitting stripped on me.
    I had tried to save some money and had ordered a cheaper fitting for this particular connection and now I'm paying for it. So, I've ordered a new one (Vibrant Performance from Summit). I've been happy with the other Vibrant Performance fittings, so hopefully once this arrives, I can get that little piece of fuel line hooked up and attempt to fire the engine.
  49. #439
    May 2018
    Park City, Utah, USA
    ugh.... I know that feeling, Pat! I broke a fitting on a flexible fuel line - same thing where i thought, "Maybe I should tighten this just a little bit more just to be safe" and bam, I broke it... Hope you get a replacement soon!
  50. Thanks Pat427 thanked for this post
  51. #440
    New Braunfels, TX
    New Builder
    I haven't been in the garage much recently for a really good reason. I've been busy welcoming a new member to the forum. This is our first son. Welcome to the build, Emmett!
