44
132
Pat,
On the hazard switch, run the two red wires to the two center pins on the 6 pin switch. Then, put both the left and right wires on the two pins on just one end of the switch. It doesn't matter which end or which order the wires are placed. The pins on the other end of the switch will not have anything connected to them.
