TKO 600 Rear Seal
Hey guys. Took the rubber donut out of the TKO600 tonight from the rear tailhousing. Came out pretty easy. I was inspecting the seal and noticed that a portion of the right side of the seal is flipped out a bit. If you look at the picture you can see it at about the 90 degree mark. I lubed up the driveshaft and installed then removed but it doesn't seem to affect it so must be in the rubber itself.
Anyone think this would cause a leak and is it something to address now versus while in the car? The rear seal looks like a rubber press fit, so doesn't look like it would be hard to swap out, but thought I'd get some other opinions.
Thanks.
