Results 1 to 7 of 7
Thread: Hot rod power window kit and Collins frames.
    Prairieville, Louisiana
    Due to a change in the target for my build, I am selling a complete ffr power window kit and the t Collins window frames. I just checked and the kit is complete with extra nuts and bolts. I did already cut the window track, and include a part I cut i kept in case you need to lengthen it some. I cut a touch off the lower motor mount rear tabs to get them in and enough adjustment. Some bolts are trimmed to allow more window revel at the bottom (the bolts that bolt the window to the track). The window bracket is installed in the glass but if you center the track to the glass then there is enough adjustment and not need to remove. This kit is 650$ from ffr. I’m asking 400$ shipped. Feel free to ask about any details.
    The Collins design window frame is complete. All seals and rubber. It ships unassembled for size and each side will be taped up so they go together easy. Also include printed out 11x17 drawings and instructions he sends. All small hardware included and I’ll throw in some extras. Includes the Allen wrench modified to reach the top bolts. I’ll send the angle brackets I used for mounting but you’ll likely have to adapt to your car. This is near 200$ with of stuff to buy and assemble yourself. I’m asking 100$ shipped. These are sold, no longer available.
    I will def work with you if you want both of these.
    PayPal works for me, or money order. Contact me here for any questions you may have.
    The window frames and parts.
    '33 Hot Rod
    MK4 Roadster
    Stillwater, NY
    PM sent for the frames
    The frames are spf.
    '33 Hot Rod
    MK4 Roadster
    The frames are sold. The window kit still available.
    '33 Hot Rod
    MK4 Roadster
    The window kit is still available
    '33 Hot Rod
    MK4 Roadster
    Make me any kind of reasonable offer on the window kit. It's in my way and I need it gone.
    '33 Hot Rod
    MK4 Roadster
    Last bump on the window kit before I file some away in junk pile and some gonna go in garbage.
    '33 Hot Rod
    MK4 Roadster
