Thread: Slick Sand
    Member JETAV8R's Avatar
    Apr 2018
    Wilson, NC
    Slick Sand
    Sprayed a gallon of Slick Sand a couple of days ago. Blocked the hood, trunk, and doors yesterday. Blocked the body today with 220 grit. Nice 70+ degree days in NC. Will glaze the few pin holes tomorrow and then spray another gallon of Slick Sand and block again, then final sand to 400 and then 600. Then a sealer and color..
    primer.jpgblocked primer.jpg.
    MKIV Roadster #9414, Complete Kit Delivered 9/8/2018, First Start 11/9/2018, First Go Cart 11/10/2018, Ford 306 Hand Built, E303 Cam, Blueprint Engine Heads, Edelbrock Performer Manifold, Edelbrock AVS2 Carb, Roller Rockers, Tremec T5, 3.55 Moser 3 Link, 17" Halibrand Replicas, Nitto 555 G2's, Power Steering, Power Brakes, Heated Seats, Russ Thompson Turn Signal
    RJD's Avatar
    Northern Virginia
    Looking good.
    Apr 2014
    Memphis, TN
    What gun system are you using?
    Ryan
    33 Hot Rod
    Apr 2018
    Wilson, NC
    Quote Originally Posted by rychi1 View Post
    I bought this inexpensive gun to spray the Slick Sand. It has a 2.5 tip.
    https://www.ebay.com/itm/2-5mm-HVLP-...72.m2749.l2649
    I have a new DeVilbiss ********** FLG4 to spray my color and clear.
