Results 1 to 21 of 21
Thread: So Who Will Be The First?
    Northern VA
    To put this in their car? https://www.youtube.com/watch?v=2FtNlfAbc2w&t=559s
    The new 7.3 pushrod gas motor from Ford. I want to say that this will open up other options to guys that don't want to go the way of the LS. Excited to see how this performs, price, and aftermarket support.
    Mr. Scott,
    With diesel engines now being totally over complicated to meet Federal emission standards, plus diesel fuel not being what it once was from a pricing and long term stability standpoint, I think it makes sense to go down the gasoline or E85 path.
    My disappoint..(On The Surface & I'm Likely Wrong)..is seeing what Ford produced really looks like they took the LS design and simply attempted to refine it. Hopefully it will be a bit hit in their trucks and personally I'd like to see it in their Mustang's over their current V-8.
    It would be great if Ford created a Real Lincoln Continental & Mark Series plus a Real Crown Victoria designed around this power-plant because:
    >..Remember when you could tow a boat or a camper with the family sedan?
    >..Remember when a Lincoln was the American Car of Cars and made the Cadillac seem cheap by comparison?
    A Ford Fan & Customer Until 1999 When I Lost All Faith In That Brand!
    Looks mighty tall which is understandable for a truck engine---if so it may not be a good candidate for fitting under the roadster or Coupe hoods. Also being a truck engine it is probably designed around low end grunt (i.e.; bore & stroke combination and rod length, port sizes, etc.) rather than higher RPM power, much like the old 385 series engines. It'll be fun to see how it all shakes out and develops!
    Jeffski,
    I be it is a 4.125" bore with a 4.125" Stroke!
    It's 4.22 bore and 3.97 stroke (444.2 cubic inches).
    https://youtu.be/f5dMqHqC4pM
    Sep 2015
    Hamersville, Ohio
    I'd like to know the weight of that monster. Too tall!
    Here are a couple of videos that are out there:
    https://youtu.be/2FtNlfAbc2w
    https://youtu.be/dJKBm9W8qAY
    Good Luck From The Dark-Dart Side!
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I'm on the hunt for a '61 - '64 Country Squire for a dog hauler, FFR tow vehicle, and cross-country cruiser (think Rt. 66) and was planning on doing a Coyote swap. If this becomes available as a crate motor in the next year or two, it will be a candidate instead of the Coyote.
    Later,
    Mk3.1 #7074
    YES! YES! YES! In my fantasies is an early to mid 60s Country Squire Cobra hauler If you do it Chris I know it will be awesome! Hurry up, I want to see it
    Milton,DE
    Just this past weekend I saw a mid sixties Country Squire in a parking lot and said to my wife "check that out, that could be fun". She didn't see it..... I still think that it would be cool.
    Olli
    Would A 1968 Work?
    https://www.ebay.com/itm/1968-Ford-C...1:pf:0&vxp=mtr
    Northern VA
    I am so on board with this!
    Northern VA
    Dimensionally speaking, is it is not a "big block", right? . It is probably heavy, but aluminum heads would help, a little LOL
    Senior Member TheBabyBadger's Avatar
    Jan 2018
    North Bay, California
    Quote Originally Posted by scottiec View Post
    It basically is a big block. No Siamese cylinders. Larger iron block. 444 cubes. Definitely a "big block". Dimensionally, it is closer to the size (width) of a small block but is also quite tall.
    I don't see it being a hot rodder's motor, either. Gonna be a low RPM torque monster, but may be a good candidate for the '35 truck depending on weight and purpose of the 35. Strap some turbos on it maybe, according the build materials it is going to be very durable and uses many similarly finished parts (pistons, rods, etc). Might be a good truck to trade a diesel on for a refined gas engine if it tows well. I was NOT a fan of the 5.0 in the SD. Wasted engine.
    I'll let some rookies test them for a few years... jury is still out, but on the surface I think Ford did a great job!
    Gen3 Coupe - SOLD Arrival: 6/21/18 SOLD: 4/12/2019
    Current Vehicle: 2014 SRT Viper (modded to the moon), 2022 TRX, 2022 RS6, E46 LS3 M3
    Current Projects: Superlite/RCR GTR ***FOR SALE***
    @madd_wrapps on IG or www.maddwrapps.com
    Northern VA
    Good info!
    Ol Skool
    upstate NY
    Nice Videos. I haven't seen the actual bore center mentioned. The FE was 4.62" I think. They do say its a little longer than the 6.7L. Does resemble a tall deck LS in some ways. My eye caught those tall beehive valve springs which would be nice in a 500lb/inch rate! Pushrod alignment looks excellent. Stainless Exhaust manifolds look turbo ready. Pistons are so compact now. The ring pack is tight. High port heads with those tall springs means its a breather. Hopefully the plugs won't weld into the head with those tube shields on. Should have plenty of torque for the Country Squire. Will that 10 speed fit in the wagon??
    For those who have encouraged me (Mrs. Gumball would say "please don't"), my preference is a '61, which had the last vestiges of tail fins and also had the round "jet age" tail lights. Here's the look I'm going for - best would be wimbledon (creamy) white with red interior. I'd add the modern engine, good brakes, larger wheels and tires, lowered (possibly air) suspension, A/C, a decent stereo, front bucket seats with console, and go cruisin'.
    And if you're familiar with the term "lead sled" to describe '40s and '50s long, low, hot rods, then you may enjoy the license plate that I have on order for my some-day wagon that will haul my Siberian Huskies around.
    Later,
    Mk3.1 #7074
    Northern VA
    Chris that would be perfect.
    That's an awesome '61 wagon you posted. You'd want air suspension just to overcome that monster overhang in the rear when towing.
    That would definitely be an interesting build!
