Thanks Thanks:  2
Likes Likes:  3
Results 1 to 40 of 70
Thread: Engine choice input wanted.
    Jun 2017
    Norway
    Hi all.
    I am inching towards ordering a complete kit later this year or next year. Some background. I live in Norway, where it just recently became possible to build and title a homebuilt car. One of the limitations is a max horsepower of 20kw (almost 29 HP) per 100 kg (220 lbs) finished car, so about 290 hp for a 2200 Lb car. That is curb weight including all fluids, spare tire and tool kit. So, the heavier engine i have, the more horsepower i can have.
    I would like to build a roadster with the IRS, large brakes and coil overs. I am shooting for a well balanced, well handling car, a corner carver if you will. So, I was originally planning for a small block with fuel injection. But then I started reading a little bit about those BB builds, and how happy a lot of those owners are with the engine choice.
    So here's my dilemma. I have a Q-code 69 CJ428 Mach1 Mustang that'll have to go to finance my roadster. I have two engines for this car. The original CJ engine, which is complete,but in pieces needing an extensive rebuild, and another freshly rebuilt 428 sitting in the car that is a CJ engine in all respects but the block, which I think might be a SR block?? It has som ribbing down the sides externally. I was planning on selling the Mustang with both engines, but now I'm starting to wonder if I should keep the running 428 and use it in my build, and instead sell the Mustang with the original engine only.
    So I am wondering how balanced and agile a BB car will be compared a small block equipped car. It is my understanding that the Roadster is biased a little bit towards the rear weight wise, so maybe it will balance out better with a BB?
    I also don't know how much an all steel 428 equipped car will weigh, anybody knows?
    Sorry for the long post. English is not my first language, so I tend to get a bit long winded....
    May 2018
    Merritt Island, FL
    Not sure I understand the horsepower to weight requirement between metric and US. Also, how do they determine the HP? Engine or rear wheel HP? You can always de-tune an engine to reduce the HP.
    Am I reading this right? You are allowed 29hp for every 2200 lbs of completed vehicle weight? Thats about how much a Factory 5 Roadster weighs... 2200 lbs. A big block 428CJ will have over 400 hp... your car needs to weigh 30,000 lbs. To be legal, you'd have to use a 1970 Citroen 2CV engine.
    Jun 2017
    Norway
    Haha, that came out totally wrong, i'll edit it... The correct ratio is 29 hp per 100 kg, which means about 290 hp for a 2200 lbs / 1000 kg car. The horsepower is engine only, no ps/ac or such, just alternator unloaded. The CJ is rated to about 335 hp from the factory, but i dont know if they will accept that, i might have to dyno it, in which case it'll have to be detuned. I could get the curb weight up by putting a big *** spare in there and also a heavy tool kit, but not sure if the authorities would approve..Also it is possible to replace the cast iron heads and intake at a later point, so there are options.
    2200 lbs, would that be a small block car? 'Cause then a BB car would probably be about 200 lbs more??
    Hello, and welcome to the club! First off, your English is excellent! I know some native speakers who absolutely butcher the language, so no apologies needed!
    I think I understand your HP limitations. That's a curious way of managing high HP cars. I think you can put a big block in there and make it work. As mentioned, you may have to de-tune it some, but I do think it can be done. Plus, it would be great to use that engine in the Roadster.
    As far as how the handling will be, I think you will be more than satisfied. These cars handle beautifully, and the modest weight difference won't impact you too much. As some have already mentioned, you can help that by adding weight in other areas to help manage that as well. Moving the battery around is one easy way. You can be creative with helping to get the car balanced, or at least better balanced.
    Good luck as you wrap up your planning, and please keep us updated.
    Milton,DE
    Who measure the engines HP ? You or the Norway authorities? 290 HP would be a really weak BB. 290HP could be a very nice 302.
    Olli
    Is this a one time horsepower versus weight check for initial registration or something they check annually or repetitively?
    I would be real inclined to do a combination of detuning the motor and adding some significant ballast in the form of steel plates all over the place if it is a one time check and then after you get past that remove the weight and tune it.
    I see a problem w/ your two engines. The one in parts is the original engine. Whether you put it together or not, any buyer would definitely want to have it with the Mustang. I think it could make a significant difference in your selling price. So, for me, you really don't have an engine for your FFR. So now you can move on to my favorite, a 351. I don't know how often your car may need to be inspected for this HP. Is it just once when it first goes on the road, or does it happen periodically? Reason I ask is a nearly bone stock 351 would give you the 290HP, and it would be very easy to upgrade it later if that is possible. I wouldn't worry about the engine weight. We all know that a BB is heavier, we can all take it to a scale. But it would take a very experienced race driver to be able to feel what a 200# difference does to the car's handling.
  9. Likes Houdini liked this post
  10. #9
    Jun 2017
    Norway
    I have reached out to the authorities with regard to who measures the hp, but no answer yet. I agree that it would be a weak BB, but the idea of a torque monster in that little car is intriguing + some of the originals actually came with 428's. Of course there are other considerations such as what price I will get for the Mustang with only a non running engine with it, fewer transmission options??, and availability of parts...But my first concern is handling. If a BB car ends up being a nose pushing, understeering dog, at least compared to a SB car, I think I'll pass. I want it to feel nimble and agile.
  11. #10
    Having An FE Makes A Period Correct Factory Five!
    I bet detuning and adding ballast will likely get the job done.
    You can go with a very mild camshaft and install it retarded 2-4 degrees.
    The 4" frame tubes should supply the perfect hiding place for adding the ballast you need.
    Filling them with oil would gain you roughly 70 pounds that could be easily filled and easily drained.
    Pass the inspection, change the camshaft and dump the dead weight and you'll be tearing up all of Europe.
    Good Luck From The Dark-Dart Side & Please Keep Us Posted!
  12. #11
    Jun 2017
    Norway
    Thanks guys, a lot of useful input here. There is a process wherein one applies for a build permit. You have to specify drivetrain then. If it is approved, the process involves an inspection of the car after the frame is finished, and when the car is finished. There is also an inspection two years after completion. I don't think it's a good idea to try and fool the inspectors, they probably know what to look for, and if I'm busted, the whole project is jeopardized. Besides, I'm not fond of cheating, it's just not something I'm comfortable with. It seems the consensus is that a BB won't hurt handling in a big way. I do think it would be a killer engine to have in the car. I mean, the sound even from the restrictive exhaust in the Mustang is awesome. But I hear you CraigS, it's probably a lot easier to go with a 351. I guess I'll just have to put my mustang out there and see what response I get. If I get a decent price for it without the running engine, I still have the option..
    Maybe Factory Five will do some killer deals in their anniversary year? By then I have to be ready to seize the opportunity.
    After gratiously being given a ride by Alan Marshall in Cape Coral last November, I feel there is no way around it, I have to do this...
  13. #12
    O'Fallon, MO
    I just think it's terrible how many guys here are suggesting to build an illegal vehicle, shameful Your original engine, even disassembled is very valuable to a true car collector. Sell the package and get a stock 351, even 290HP is a blast in a 2400#, which after some heat and sound insulation is about where you'll be.
  14. #13
    Jun 2017
    Norway
    Hi Rich. I wasn't really offended by the suggestions, I do what I feel is right personally. I would love to put an unlimited amount of horsepower in the car, but historically, anything pertaining to modifying and importing cars has been extremely difficult, so the fact that it now is possible to build a kit car at all is a huge deal. In light of this, I'll take 290 HP all day long, I think it is more than enough for me.
    I will never sell the Mustang without the original engine, that would be a crime. I would only keep the quasi CJ engine, and even there, I could probably sell off some of the CJ specific parts.
  15. #14
    You could consider building a mild cammed 428 and choking it down simply by running an Edelbrock AVS 500 CFM carb and holding your initial distributor advance to 7-8 degrees.
    When you want to get a little more power, stick on an Edelbrock AVS 800 CFM carb and let her rip and roar or simply stuff in a 302 crate motor and call it a day.
    Sorry that you have little or no wiggle room regarding your Government's Red Tape!
    We've got places (States) like that over here in the U.S.A. that are pretty bad too.
    I'm thankful to not live in one of them.
    Good Luck From The Dark-Dart Side!
  16. #15
    RR20AC's Avatar
    Puyallup/WA
    Oystein, Why not get a 289 kit an add a 289. Would be a corner carver like you wanted and have all the attributes of an original Cobra and fit with regulations too.
  17. Likes cnutting liked this post
  18. #16
    Jun 2017
    Norway
    You know, that might be a good solution if I end up using the 428. A carb swap is no more than couple of beers time,easy peasy.
    Btw, I now what you mean about some states being worse than others. I once brought a 77 SE TA from SC to CA. They made me put catalytic converters on that thing...
  19. #17
    Quote Originally Posted by RR20AC View Post
    Excellent Idea!
    It was the 289's that won all the races even though the 427's got all the attention.
  20. #18
    Quote Originally Posted by Oystein View Post
    The 500 and 800 are both square-bores and seem to stumble less than the 650 CFM series that have 250 CFM butterflies up front with 400 CFM butterflies out back.
    https://www.edelbrock.com/shop/carburetors.html
    For the record, I'm in the minority regarding the Edelbrock AVS Carbs and I'm also in the minority regarding my driveline choice as well.
    https://youtu.be/wOID7yvBRPU
  21. #19
    Jul 2014
    colorado springs co.
    Go with the big block. If your thinking about it and you dont do it you will always open the hood and wish it was a big block. Im building my third cobra(in build thread under feadam) this one with another big block. You can always play with suspension for handling and how many of these cars get pushed to limit of handling anyway. With the engine so far back most drivers would never differentiate if car was big or small block. My second car was small block, but I always missed that torque of the first car which was a 428. This one I'm building is a 482 and cant wait for that acceleration.
  22. #20
    Jun 2017
    Norway
    RR20AC, I don't think I'm going for the original look anyway. With a small block, I kinda envisioned an eight stack type of fuel injection. Mostly because I think it looks cool. I'm not concerned with regulations either, will not be racing it.
    With an original CJ mustang, I feel obligated to keeping it original, and I've come to the realization that this is not my game. I want to improve and modify stuff. With a FFR Roadster i have a feeling it'll never be quite finished, which suits me well.
  23. #21
    Jun 2017
    Norway
    Feadam, I'll make sure to look at your build thread. I'm thinking..Say I'm limited to 290 HP no matter the engine. Would a 290 HP big block engine allow lower gear ratios and better performance than a 290 HP small block?
  24. #22
    Jul 2014
    With the long stroke of the 428 your going to have a lot of torgue. Acceleration wont be a problem. You could probably go with a 3.27 gear still have great acceleration and good cruising RPM.
  25. #23
    Jun 2017
    Norway
    Hmm. The Mustang is about 1000 lbs heavier, it has a 3.50 rear end, and it goes pretty good... I think you're on to something here. What transmission are you running?
  26. #24
    Jul 2014
    Top loader 4 speed, when you look at my build it has the parts and pictures of most drive train parts.
  27. #25
    Sep 2015
    Beachside
    What I would have suggested, but maybe I'm a bit biased...
    FFR #8833 289 FIA 3-link
  28. #26
    O'Fallon, MO
    A 290hp small block will out perform a 290hp big block on road. Why choke a 428 down to nothing when you could have a nice free breathing 302 or even a 351. The thought of castrating a 428 makes no sense. Plus the lighter car will handle better.
  29. #27
    I agree. Plus I have to assume the inspectors have some knowledge. If I were them, I'd look at that tiny carb on a 428 and immediately figure you are planning to swap the carb as soon as they pass you. I like your stack injection idea. As a point of reference a stock efi Fox 302 was advertised back then as 225 HP. So a bone stock 302 + stacks might be exactly what you need. Maybe add one of the mild Ford letter cams.
  30. #28
    greenwood sc
    When I built my FFR back in 2012, there was a member who built a 289 slabside car. He did an undercar exhaust and all the other details. I think this look works great with lower HP. I love the slabside look. This may have been the thread:
    https://thefactoryfiveforum.com/show...bside-Finished
    MKIV #7619 complete kit IRS, 351 TKO 500, Delivered 11/13/2011
    First start 12/31/2011
    Gocart 01/12/2012
    completed tags/title 05/11/2012
    http://thefactoryfiveforum.com/showt...-Graduate-7619
  31. #29
    Southport, NC
    I agree with the Ford SB 302. Add shorty headers and you can enlarge both the footboxes for comfortable cruising.
    GT40p heads with a Trick Flow mild cam and valve springs will get you in the range of 290HP. A strong dependable engine.
    George
  32. #30
    Jun 2017
    Norway
    It's not an easy decision to make for sure. It seems to me a BB car will handle pretty well, which is what I was curious about. The next step is to determine how the authorities determine HP, and see if there is any wiggle room. I have also started the process of selling my Mustang. I'll have to see if I can get a decent price for it without the running engine. If not, I will sell it with both engines and take it from there. Regardless, I will be looking into the crate engine suggestions, those are very interesting.
  33. #31
    Colorado Springs
    Trying to choke down a 428 to make only 290 hp will make it very inefficient. Even if you destroke it to a 390 and limit it to 5500 rpm's. An efficient engine makes about 1hp per cube. It will look good, but it won't run well at all.
    Sell the CJ, they are pretty valuable. Install a nice 302 fuel injected small block. It will be efficient, fun to drive, and last forever.
    .boB "Iron Man"
    www.RacingTheExocet.com
  34. #32
    Jun 2017
    Norway
    Quote Originally Posted by Bob Cowan View Post
    All good points for sure. Sounds like the easier way to go as well. Small block is still plan A, but I want to explore the possibility of using the 428 since I have it here already.
  35. #33
    Lucky I live in the free State of Arizona where the gov't is not overly restrictive but if I was faced with a specific HP per weight limit I'd take a much different approach and use a smaller turbo or supercharged engine that I could easily regulate the HP. A low compression ratio that when limited to low boost would provide something just below the max HP for the vehicle's weight but a simple pulley change (or better yet, a boost controller for a turbo) and I would have a screamer. It just depends on the rules around how HP is measured. Not much different than racing -- rules are there to limit you and your job is to stay within the rules while increasing performance without the tech inspector calling you out for a violation.
    I understand your desire to run a big block and I read where others have chimed in about the extra weight not being a performance issue. But the fact is, adding weight does affect performance. Until you suspend the laws of physics and that little issue of inertia you will be affecting performance. In your case, not linear acceleration as you already have a HP/weight limit that will limit straight line acceleration but lateral acceleration (cornering) and breaking will be affected by adding more weight. Yes you can mitigate the effects somewhat but it is easier to tune a light car to weave through the cones than a heavy car. So working within the rules you've been given I suggest you consider the pros and cons of how to achieve your HP/weight limit and maximize your handling performance. Adding weight so that you can run more HP will not give you added performance in any measurable category. Acceleration is governed by HP/weight if all other variables are constant. A lighter car with less HP can accelerate the same as a heavy car with more HP. Try outrunning a motorcycle at a stop light. But can you expect a heavier car with the same tires, weight bias, and brakes to stop in the same distance as a light car? Is overall performance more important than HP or engine selection?
    The car you are considering building is NOT A FORD so why box yourself in with only Ford power? And whatever is under that hood is hidden until you open the hood to reveal it. If you are building a performance car use whatever parts that meet the goal of maximum performance within your budget. If you are more interested in building a replica of a Cobra then you have just limited yourself to the only practical choice -- a low performance SBF that is a faux copy of a real performance car that was Shelby's vision. And what if he would have gotten a better partnership from Chrysler -- would we see a cottage industry of imitation Shelby Cobras powered by a 392 Hemi?
    Whatever you decide -- have fun with your build. And however you build it or personalize it; no one can say it's wrong.
  36. #34
    On a roll Al_C's Avatar
    Wheaton, IL
    I'll offer my opinion, too, for whatever that is worth. Your choice depends on your goals. If you really want the look of a big block, then you've got at least part of the solution (whichever 428 you use). If you want the "corner carver", go with a small block. I agree with others - I believe that a stock small block will run a heck of a lot better than a de-tuned big block. To quote Mike Forte - "one of these with a 289 and a 2-barrel would be a lot of fun". In other words, a 290 hp small block, whether it's a 289, 302 or 351, would be a great solution. So to me, determine the vision and your choice becomes clear.
  37. #35
    Jun 2017
    Norway
    OK, so i've searched a bit locally in forums, and there are some hints that the HP limit may be exceeded somewhat, so i've reached out to our "DMV" to see what they have to say about it. I bragged about the excellent qualities of the FFR chassis, i just hope i didn't lay it on to thick....If i cant go above 300 hp with the 428, i think i'll probably follow the advice from some here and go with a small block. I've looked at Blueprints offerings, a lot of nice engine/trans-combos there. . The 428 can always sit on display in the garage, its nice to look at:-)
  38. #36
    Jul 2014
    The thing that matters most is that what ever you do it makes you happy, big or small block, these cars are a lot of fun and ill bet you will have one of the only ones in Norway.
  39. #37
    Jun 2017
    Norway
    Quote Originally Posted by feadam View Post
    OH, absolutely, it's my project, and I'll do it the way I want to. But it would be foolish not to take advantage of the vast knowledge of this community. If (when) i get a kit, this won't be the last you've heard from me..
    There are a few cobra replicas and maybe even some originals in Norway, but I haven seen any FFR Roadster yet. I go to Florida about twice a year, so I have seen some there. I even got a ride in one. That was particularly valuable for me, as i got to experience how solid the design is. Very tight and no rattles and squeaks. And the sound and the smell sitting at the traffic lights.....just WOW!
  40. #38
    May 2018
    Merritt Island, FL
    Where in Florida?
  41. #39
    Jun 2017
    Norway
    Quote Originally Posted by davekp View Post
    Where in Florida?
    Cape Coral. Love it there!
  42. #40
    Senior Member MPTech's Avatar
    St. Louis, MO
    What if you just ran a restrictive air filter/carb and restrictive exhuast? You could easily upgrade / downgrade as needed.
