Results 1 to 25 of 25
Thread: What's wrong with this picture?
    Parker, CO
    There are 10 types of people in this world;
    those who understand binary and those who don't.
    Norton, MA USA earth
    LOL that's funny.
    Jan 2019
    Oops!
    Cant look at both sides at the same time. No will notice.
    On a roll
    Al_C's Avatar
    Wheaton, IL
    Quote Originally Posted by nthompson View Post
    Oops!
    I'll second that!
    Mk IV Roadster - #8650 - delivered 7-17-2015 - first start 7-28-2018 - first go-kart 10-13-2018: a work in (slow) progress
    mburger's Avatar
    Punta Gorda FL
    Looks like the Shroud of Turin
    Mark
    Mk1, Frame #1929 stock 1990 EFI 302, T5, 8.8 axle 3:55, PS, Heidts, heat, fresh air vents, Russ Thompson Turn Signal mod, windshield wings FFR front lower control arms, Speedhut gauges, Alex's glovebox, cup holders. charging ports. 70K on the motor and 7,200k on the car.
    Oct 2018
    I hate it when that happens.
    BadAsp427's Avatar
    Summerville, SC
    I just went out and looked at mine, they are ok. I was going to offer to swap if I had the same problem.
    Mk4 20th Anniversary #8690 ( #8 of 20 ) Purchased 8/18/18----Build Started 8/19/18
    First Start 11-1-18
    ---- First GoCart 11-7-18
    BluePrint Engines 347ci / TKO600
    Carb / Heater / Heated Seats / Cruise Control / Drop Trunk & Battery
    Build Thread Click Here Gel Coat Driver 1/12/19 - Hit 1000 Miles 3-23-19
    Parker, CO
    Thanks, Carl. I appreciate that. I sent an e-mail to FFR with a picture and asked that they send a replacement to match the one that has the long side of the diamonds running top to bottom. I expect they will have one on the way tomorrow.
    FF6602's Avatar
    Nov 2018
    State College, PA
    Looks like your "Quality Control" process was better than the guy who put the raw material in the press! What a mesh he made of it!
    Craig
    10/2018 -- acquired Mk 3.1 #6602, unfinished, go-kart stage; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; T5 and donor stock 2.73 rear diff (for now); my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    Here's another option:
    BTW all these grates tend to rust so a shot of clear is a good idea.
  12. Thanks Papa thanked for this post
  13. #12
    Not a waxer
    Jeff Kleiner's Avatar
    The FFR ones like Papa Dave has are aluminum so rust is not an issue.
    Oct 2017
    Just tell everyone they are designed that way for "aerodynamics"...
  15. #14
    Bakersfield, CA
    Dave (papa), it would be a good conversation piece of your “unique” build. I think it would be fun to see how many people would actually catch it.
    Dave (Hodgkins), that’s really cool looking honeycomb... where did you find that?
    Kurt
    Build thread
  16. #15
    Kurt
    Hi Kurt,
    I got mine from a local So-Cal dealer called Industrial Metal Supply:
    https://www.industrialmetalsupply.co...pss223624025hx
    PS they also have a great deal on NOMEX, which you can use on top of your radiator. I painted mine black before installing it:
  17. #16
    Vertical goes on the Right, Horizontal on the Left.....thought everyone knew that...da Bat
  18. #17
    Your left, or my right?
  19. #18
    Bakersfield, CA
    Sitting in the car or looking at it from the front?
    So many variables.....
    And thanks Dave! And it looks like you engined turned that radiator cowl???? I must have missed that (or forgot, I’m old) in your refresh thread.
    NOMEX? Radiator? Like in front of it? Doesn’t restrict airflow?
    Kurt
    P.S. I found the NOMEX and radiator shroud on your thread Dave
    Build thread
  20. #19
    The dirt track guys swear by it - saving radiators from mud / rocks / etc.
    I'm using it too - pretty much requires a fan shroud in hot weather / hard running to move enough air.
    https://www.summitracing.com/parts/a...kaAvotEALw_wcB
    To be clear, I was doing Ok on water temp autocrossing running the FFR supplied fan mounted to the back of a Summit radiator.
    First autocross with the honeycomb - the stone guard had to come back off - climbing water temp.
    Ok for years (with honeycomb) after adding a Summit fan shroud to the FFR supplied fan.
    393w / 10:1 compression.
    https://www.summitracing.com/parts/sum-380424/overview/
    https://www.summitracing.com/parts/sum-381213/overview/
  21. #20
    Feb 2013
    I powder coated my grates silver.
  22. #21
    Parker, CO
    Quote Originally Posted by Driver_WT View Post
    I plan to do the same.
  23. #22
    Stafford Virginia
    If you decide to use the Nomex don't forget to order the mounting kit, a simple way to attach the Nomex to your radiator.
    JR
    MK4 complete kit #9059 ordered 1/19/17 delivered 3/23/17, 2015 IRS, Fortes/DART347,TKO 600, hyd clutch, P/S, 12.88 wilwood brakes front and rear, high back kirkey seats, heater/defrost and vintage gauges
    First start and go-cart 4/11/18
  24. #23
    Well, YES !
  25. #24
    Parker, CO
    I got an e-mail from Dave C. at FFR and he personally made a new set for me and they are on the way. Another example of FFR's great customer support.
  26. #25
    Jax Beach, FL
    It depends on the front end alignment.
