Results 1 to 25 of 25
Thread: What's wrong with this picture?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    LOL that's funny.
    Jan 2019
    Oops!
    O'Fallon, MO
    Cant look at both sides at the same time. No will notice.
    On a roll Al_C's Avatar
    Wheaton, IL
    Quote Originally Posted by nthompson View Post
    Oops!
    I'll second that!
    mburger's Avatar
    Punta Gorda FL
    Looks like the Shroud of Turin
    Mark
    Oct 2018
    central Iowa
    I hate it when that happens.
    BadAsp427's Avatar
    Greeneville, TN
    I just went out and looked at mine, they are ok. I was going to offer to swap if I had the same problem.
    Thanks, Carl. I appreciate that. I sent an e-mail to FFR with a picture and asked that they send a replacement to match the one that has the long side of the diamonds running top to bottom. I expect they will have one on the way tomorrow.
    Legal: 1/30/2020
    FF6602's Avatar
    Nov 2018
    State College, PA
    Looks like your "Quality Control" process was better than the guy who put the raw material in the press! What a mesh he made of it!
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
    Here's another option:
    BTW all these grates tend to rust so a shot of clear is a good idea.
  12. Thanks Papa thanked for this post
  13. #12
    The FFR ones like Papa Dave has are aluminum so rust is not an issue.
    Oct 2017
    Just tell everyone they are designed that way for "aerodynamics"...
  15. #14
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    Dave (papa), it would be a good conversation piece of your “unique” build. I think it would be fun to see how many people would actually catch it.
    Dave (Hodgkins), that’s really cool looking honeycomb... where did you find that?
    Kurt
    Build thread
  16. #15
    Quote Originally Posted by SSNK4US View Post
    Kurt
    Hi Kurt,
    I got mine from a local So-Cal dealer called Industrial Metal Supply:
    https://www.industrialmetalsupply.co...pss223624025hx
    PS they also have a great deal on NOMEX, which you can use on top of your radiator. I painted mine black before installing it:
  17. #16
    Vertical goes on the Right, Horizontal on the Left.....thought everyone knew that...da Bat
  18. #17
    O'Fallon, MO
    Your left, or my right?
  19. #18
    Bakersfield, CA
    Sitting in the car or looking at it from the front?
    So many variables.....
    And thanks Dave! And it looks like you engined turned that radiator cowl???? I must have missed that (or forgot, I’m old) in your refresh thread.
    NOMEX? Radiator? Like in front of it? Doesn’t restrict airflow?
    Kurt
    P.S. I found the NOMEX and radiator shroud on your thread Dave
    Build thread
  20. #19
    The dirt track guys swear by it - saving radiators from mud / rocks / etc.
    I'm using it too - pretty much requires a fan shroud in hot weather / hard running to move enough air.
    https://www.summitracing.com/parts/a...kaAvotEALw_wcB
    To be clear, I was doing Ok on water temp autocrossing running the FFR supplied fan mounted to the back of a Summit radiator.
    First autocross with the honeycomb - the stone guard had to come back off - climbing water temp.
    Ok for years (with honeycomb) after adding a Summit fan shroud to the FFR supplied fan.
    393w / 10:1 compression.
    https://www.summitracing.com/parts/sum-380424/overview/
    https://www.summitracing.com/parts/sum-381213/overview/
  21. #20
    Feb 2013
    I powder coated my grates silver.
  22. #21
    Quote Originally Posted by Driver_WT View Post
    I plan to do the same.
    Legal: 1/30/2020
  23. #22
    Senior Member jrcuz's Avatar
    Stafford Virginia
    If you decide to use the Nomex don't forget to order the mounting kit, a simple way to attach the Nomex to your radiator.
    JR
  24. #23
    Well, YES !
  25. #24
    I got an e-mail from Dave C. at FFR and he personally made a new set for me and they are on the way. Another example of FFR's great customer support.
    Legal: 1/30/2020
  26. #25
    Jax Beach, FL
    It depends on the front end alignment.
