Results 1 to 25 of 25
Thread: What's wrong with this picture?
    Norton, MA USA earth
    LOL that's funny.
    Jan 2019
    Oops!
    Cant look at both sides at the same time. No will notice.
    On a roll Al_C's Avatar
    Wheaton, IL
    Quote Originally Posted by nthompson View Post
    Oops!
    I'll second that!
    mburger's Avatar
    Punta Gorda FL
    Looks like the Shroud of Turin
    Mark
    Oct 2018
    central Iowa
    I hate it when that happens.
    BadAsp427's Avatar
    Greeneville, TN
    I just went out and looked at mine, they are ok. I was going to offer to swap if I had the same problem.
    Thanks, Carl. I appreciate that. I sent an e-mail to FFR with a picture and asked that they send a replacement to match the one that has the long side of the diamonds running top to bottom. I expect they will have one on the way tomorrow.
    FF6602's Avatar
    Nov 2018
    State College, PA
    Looks like your "Quality Control" process was better than the guy who put the raw material in the press! What a mesh he made of it!
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
    Here's another option:
    BTW all these grates tend to rust so a shot of clear is a good idea.
  12. Thanks Papa thanked for this post
  13. #12
    The FFR ones like Papa Dave has are aluminum so rust is not an issue.
    Oct 2017
    Just tell everyone they are designed that way for "aerodynamics"...
  15. #14
    Bakersfield, CA
    Dave (papa), it would be a good conversation piece of your “unique” build. I think it would be fun to see how many people would actually catch it.
    Dave (Hodgkins), that’s really cool looking honeycomb... where did you find that?
    Kurt
    Build thread
  16. #15
    Kurt
    Hi Kurt,
    I got mine from a local So-Cal dealer called Industrial Metal Supply:
    https://www.industrialmetalsupply.co...pss223624025hx
    PS they also have a great deal on NOMEX, which you can use on top of your radiator. I painted mine black before installing it:
  17. #16
    Vertical goes on the Right, Horizontal on the Left.....thought everyone knew that...da Bat
  18. #17
    Your left, or my right?
  19. #18
    Bakersfield, CA
    Sitting in the car or looking at it from the front?
    So many variables.....
    And thanks Dave! And it looks like you engined turned that radiator cowl???? I must have missed that (or forgot, I’m old) in your refresh thread.
    NOMEX? Radiator? Like in front of it? Doesn’t restrict airflow?
    Kurt
    P.S. I found the NOMEX and radiator shroud on your thread Dave
    Build thread
  20. #19
    The dirt track guys swear by it - saving radiators from mud / rocks / etc.
    I'm using it too - pretty much requires a fan shroud in hot weather / hard running to move enough air.
    https://www.summitracing.com/parts/a...kaAvotEALw_wcB
    To be clear, I was doing Ok on water temp autocrossing running the FFR supplied fan mounted to the back of a Summit radiator.
    First autocross with the honeycomb - the stone guard had to come back off - climbing water temp.
    Ok for years (with honeycomb) after adding a Summit fan shroud to the FFR supplied fan.
    393w / 10:1 compression.
    https://www.summitracing.com/parts/sum-380424/overview/
    https://www.summitracing.com/parts/sum-381213/overview/
  21. #20
    Feb 2013
    I powder coated my grates silver.
  22. #21
    Quote Originally Posted by Driver_WT View Post
    I plan to do the same.
  23. #22
    Senior Member jrcuz's Avatar
    Stafford Virginia
    If you decide to use the Nomex don't forget to order the mounting kit, a simple way to attach the Nomex to your radiator.
    JR
  24. #23
    Well, YES !
  25. #24
    I got an e-mail from Dave C. at FFR and he personally made a new set for me and they are on the way. Another example of FFR's great customer support.
  26. #25
    Jax Beach, FL
    It depends on the front end alignment.
