Thanks Thanks:  2
Likes Likes:  4
Results 1 to 10 of 10
Thread: Nor Cal wine country build starts
    Member Mrallsport32's Avatar
    Aug 2017
    Cotati California
    248B38DE-AF40-4836-90CC-64DBC71699CF.jpeg[ATTACH=CONFIG]102025[/ATTACH
    Welp my Gen 2. 33 hot rod chassis #1121 complete kit was delivered today by Eric from Stewart Transport.
    So I went to build school last February. I was intending to build a steel bodied 33. When I finally got someone from F5 to say no more steel bodies I decided to go ahead and order the regular body.
    I have to say After my inventory and body inspection today, (With help from friends), I like the look and finish of the car body. I did not have the chassis coated by F5 and chassis welds look good. So for day one I’m very happy, Besides the back ordered parts I mean. Haha.
    Do I have a plan.....kinda. Since I’m retired and have the time, I want to complete the build in one year or less. I do have some experience with building a few race cars, also my Dad owned and operated an automotive garage in Marin co. Ca. For nearly 50 years so our family has an automotive background. Hope that helps me now. I’m trying to do a fairly simple build nothing that I haven’t seen you guys do already.
    The 33 is going to be a fenderless roadster. No top, maybe add a soft top later.
    Engine: Full roller Small block Chevy 400. Transmission is a 700r4 from TCI.
    Fuel system FI tech dual quad fuel system.
    Rear is IRS with 3:55 gears.
    I’ve been lurking on this board for years reading and learning as much as possible.
    Now I’m probably going to be asking some silly questions (insert eye roll here) that have already been asked, because for whatever reason I can’t seem to use the search tool on this forum worth a darn. Anyway here’s to day one done.
  2. Likes Fman liked this post
    Nov 2016
    Petaluma, CA
    Hello, where are you in NorCal? I am in Sonoma county. Joel
    mburger's Avatar
    Punta Gorda FL
    To search the forums, put this into a Google search. site:thefactoryfiveforum.com <what you are searching for>
    For example, to search for 33 wipers, do this:
    site:thefactoryfiveforum.com 33 wipers
    Mark
  5. Thanks Mrallsport32 thanked for this post
  6. #4
    Oct 2014
    Vermilion, OH
    Congrats on the new Hot Rod
    CVOBill
  7. #5
    NY
    Congrats!
  8. #6
    Aug 2017
    Cotati California
    I’m in Cotati
  9. #7
    Senior Member gtaroger's Avatar
    Trenton Mi
    Congrats! Roger
  10. #8
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by Mrallsport32 View Post
    You need to shoot for the record on building the Hot Rod. CVOBill did his in 88 days....
    You can do it!
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  11. Thanks CVOBill thanked for this post
    Likes CVOBill, Mrallsport32 liked this post
  12. #9
    Member Dewey McBride's Avatar
    Fairfield Ca
    Congrats! Can't wait to follow your build from Fairfield
  13. #10
    Aug 2017
    Cotati California
    Gen 2 chassis #1121 delivered 2-10-19. SBC 400 with FI Tech dual quad, 700R4 trans and IRS.
  14. Likes FF33rod liked this post
