Thread: Coyote MAF Location/Orientation
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Coyote Installers.
    Looking for some input on the orientation/location of the MAF on the intake tube.
    If I look at the set-up on a Mustang (example attached) it looks like it should be clocked on the side opposite the engine (would prefer to tuck it away on the bottom/back of the intake tube if possible).
    Thoughts ?
    Are you using one of the Factory Five recommended CAI setups? Their instructions list Spectre and Treadstone Performance. Either are good choices. In both cases the actual location of the MAF sensor is dictated by the MAF tube. It's generally recommended to clock the tube so the sensor is on the outside of the curve. For the setup in the Roadster, that puts the MAF sensor pointing roughly toward the front of engine compartment. I don't know how critical it is, but I followed these recommendations with mine and it seems to work fine.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread and Video
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
    On a roll Al_C's Avatar
    Wheaton, IL
    I guess there are some things you just take on faith. I still can't understand why it makes a difference which way you put the MAF sensor, but I followed the advice and put mine in as Paul identified. Initially, I had mine on the inside of the curve, and it worked fine there, too. I did have a starting problem which is why I moved it to the recommended location, but as it turns out, my start problem was fuel related, not because of the MAF sensor.
    Mk IV Roadster - #8650 - delivered 7-17-2015 - first start 7-28-2018 - first go-kart 10-13-2018: a work in (slow) progress
    The hills of TN
    Air will put more pressure and flow velocity on the outside of the elbow. Inside the elbow can give it a lower than actual reading due to the decrease in pressure at the turn, lower readings thinks its less air entering therefore cutting fuel flow and possible lean condition.
    Disclaimer: this may or may not be true for air but that's how we measure liquid flow here at work.
    If in doubt......flat out-Colin McRae
    Coupe #485
    Raleigh NC USA
    Believe TNcoupe is correct. One of our guys was having some issues & they went away when the tube was rotated to put the sensor at the front.
    Kevin
    MKIV #8234
    Coyote '13/TKO-600
    Wheaton, IL
    Quote Originally Posted by TNcoupe View Post
    While this wasn't my thread to begin with, I do appreciate the answer!
    Mar 2017
    Yes, running a Spectra CAI.
    Thanks all for the responses and background. Make sense. My plan was to mount the sensor in the front, although I was hoping to tuck it away on the bottom to make it look pretty
    Function over fashion.
    Thanks again
Levy Racing
