Results 1 to 10 of 10
Thread: Looking to buy a type 65 in any stage of build
    Feb 2019
    I'm finally going to pull the trigger.
    But life is busy and I've considered buying your project. I would consider one in any stage of build if the price is right.
    I would also consider a complete car, once again if the price is right.
    Looking for a type 65, pretty strong on power but nothing too hot. 350+ horsepower. Fuel injection would be neat, but not a deal breaker. Must be a manual transmission.
    Let me know if you have something!
    SYRACUSE NEW YORK
    If you can send me your e-mail address, I can send you photos and specs of my car.
    My e-mail address [email protected]
    John C. Thomas
    May 2019
    Foothill Ranch
    Selling a brand new MKIII Roadster, complete minus paint!
    *Ford 8.8 rear end with 3.08 gear ratio.
    *5 lug 17x8 and 17x10.5 halibrand replica wheels wrapped in Toyo Extensa II tires.
    *Whitby motors power booster brake kit.
    *Ceramic coated headers and side pipes.
    *Ron Francis complete wring harness.
    *Breeze automotive brand new gas tank kit, radiator support bracket, aluminum fan shroud.
    *Battery isolator key switch, remote battery jumper terminals.
    *TKO 500 3:27 transmission, 31 spline 11.25” driveshaft, Powergrip 10.5 550hp clutch kit, McLeod 157 tooth steel flywheel.
    *Ford 351w engine stroked to 396, Trick flow heads, full roller block,1 piece rear main, moly rings, holly double pumper carburetor, holly mechanical pump, MSD ignition system with rev limiter, 436hp with 448ft lb torque, engine has 5yr 50k mile Warranty.
    *Starter Powermaster Mastertorque 9603.
    *3 link rear, coil-overs all 4 corners.
    *New North race cars Brake kit with 13” slotted rotors, front large GT twin piston calipers, rear twin piston calipers with mechanical E brake, factory five e brake handle kit.
    *Custom FFMetal battery box with cover, Optima red top battery.
    *Full leather interior and leather wrapped dash.
    *AutoMeter ProComp Ultra Lite gauges.
    *Aluminum dual row radiator with aluminum shroud, electric fan on 180 degree temp switch, aluminum overflow.
    *Front oil cooler, auxiliary oil filter, braided lines with AN fittings.
    Sep 2019
    Hi I have this. Maybe you’ll be interested ! Thanks https://www.ebay.com/itm/1965-Shelby...c-8f7528e15eb7
    Jul 2017
    Roy,
    Don't know if you found anything yet.
    I just posted my 2007 Roadster MK III for sale.
    75-80% complete.
    Rick K
    https://thefactoryfiveforum.com/show...MK-III-22K-OBO
    Mar 2017
    For sale Factory Five Gen 2 Type 65 Coupe
    I purchased a complete kit in 2012 and worked on it off and on in between spinal surgeries until 2016 when I had to have the lower half of my spine fused. This week I started up again only to realized I can't get in. All the mechanical and electrical about 90%
    Some of the parts are: complete kit with IRS
    Ford Racing all aluminum 427 engine M-6007-Z427AFT with Magasquirt stack fuel injection with, serpentine belt drive, AC, power steering with pressure control valve , MSD LS1 coil packs, 2 knock sensors and oil separator in the PCV system. I have dyno sheet
    Quick Time SFI bell housing
    Ram double disk clutch
    Keisler SS 700 OD transmission / 5 speed all gears synchro even reverse
    Drive shift loop
    Lincoln MK VIII IRS with heavy duty rear cover and Torsen LSD with 3:55 gears
    Wilwood disk breaks / 6 piston fronts and 4 piston rear
    QA1 double adjustable shocks with needle bearings between springs and spring perch
    Polished stainless steel side pipes – one pipe per side
    Front and rear sway bars – not installed
    Goodyear Eagle F1 275 front 315 rear on Factory Five wheels
    2 speed fan
    Custom engine turned stainless steel dash with data logging gauges and GPS 200 MPH speedo
    Both coupe bucket seats and leather roadster seats
    Cruse control – not installed
    Fire system
    All aluminum panels are powder coated silver
    2 cameras – one backup one forward facing
    Dynamat sheets
    Everything to finish the car and much more
    Asking $45,000
    Bill Lomenick
    805.522.9808
    [email protected]
    Chotis Bill
    Feb 2019
    Roy, If you haven't found one yet let me know........ text or call 484-798-8754 i can forward pictures and info. Domenic
    Feb 2019
    attached photo of Daytona image0 (1).jpeg contact Domenic @484-798-8754 e-mail [email protected]
    Woodstock ,Illinois
    65 Cobra Dude has a BEAUTIFUL 3rd gen coupe with coyote, a/c, IRS, sound system...you name it ! It’s a stunner!
