Results 1 to 10 of 10
Thread: 3D printed parts
    3D printed parts
    3D printing is my latest project!
    I would like to share with you some parts that I've designed and printed for my FFR:
    Grommet for shoulder holes of Kirkey 47-series tall back aluminium seat
    https://www.thingiverse.com/thing:3424206
    Steering wheel trim for dash of the Factory Five Roadster Mk4 car kit
    https://www.thingiverse.com/thing:3424193
    Door latch spacer
    https://www.thingiverse.com/thing:3424200
    Feel free to use and customize!
  2. Likes kgkeys liked this post
    Bakersfield, CA
    That is soooooo cool!!!!
    Build thread
    Chino Valley, Arizona
    Very very cool!
    Seasoned Citizen NAZ's Avatar
    Agree, very cool.
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    I like it! I have two 3D printers at work (FDM & Objet) - I have a ton of custom ideas I want to 3D print and test out. Could even use the 3D printed objects as a base for laying up fiberglass mods if desired. I do worry about the 3D printed parts being exposed to sunlight and heat for extended periods of time. Most of the resins are ABS or nylon - they can sag / creep with time and especially heat exposure. But for applications like you posted, it should work perfect.
    I had looked at 3d printers for a few years, and seeing some of the ducts that redfogo came up with got me to talk with him...he convinced me to go for it. Worst thing about it is that it's taken some time away from the 818. Pretty sure I'll get some of it back by creating solutions with the thing. Recently made an ECU panel for another builder.
    Fiberglass is a great idea, but there is a guy over on the midlana forums printing parts and then casting them with aluminum. I made a contraption to melt aluminum a few years ago but tried it with varying thicknesses of steel cans and they all melted, lol. Now the bottom is full of aluminum.
    Thank you for the positive comments. I’m still learning, but having lot of fun.
    I agree about temperature concern. I don’t think anything under the hood would survive. Right now I´m using PLA filament which is the easier to work with but is low temp. ABS would be more heat resistant but is more difficult to print.
    For the fiberglass, I´m skeptical. It’s really time consuming to print anything bigger than 6in., which is fairly small for any fiberglass work.
    Feb 2018
    Austin, TX
    Quote Originally Posted by totem View Post
    Yep we have a commercial printer (~$50K) so the build platform has much larger envelop - we can do bigger parts. Most of the software will also let you split the part and print it in 2 sessions - it will put in interlocking/alignment features in the break line. But yes I agree...bigger parts do take a long time to print no question. Our build layer thickness is about .007" on finest resolution and about .013" thick at the lowest resolution.
  10. #9
    Senior Member Mick40's Avatar
    Mass
    Hi Totem,
    What 3-D printer are you using? Thinking about a Crealitiy Ender-3. Nice job! Someone a while back printer blocks for their wipers, wondering how they have held up.
    Thanks for sharing!
    Mick
  11. #10
    Quote Originally Posted by Mick40 View Post
    Hi Totem,
    Thanks for sharing!
    Mick
    I have a Ender-3. It’s open source, hardware and software. Lots of mods, parts and upgrades are available. It’s in the Factory Five DIY mindset!
