Results 1 to 3 of 3
Thread: Engine management system
Hybrid View
    Sweden
    I am planning to build a ffr 33 hotrod with 4.6L or 5.0L Coyote from a mustang.
    What do I need to get the engine running?
    Can I get the original ECU from the donor car, or should I go with aftermarket?
    What alternatives do I have?
    /Daniel
    St. Louis, MO
    The Parts Farm on ebay sells used mustang running gear packages out of mustangs with the PATS turned off. My understanding is that PATS is the biggest issue with using a donor engine and ECU. Here is one of their listings:
    https://www.ebay.com/itm/72k-2011-20...KXd:rk:19:pf:0
    I don't know anything about them, I just noticed that they claim to be able to disable the PATS. It might be worth a call to them to find out more.
    Wibby
    Maricopa AZ
    Holley makes management systems for both the 4.6 and coyote. If you use a new rate coyote it comes with the engine harness and you can get the ECU and required pieces through Ford Racing.
