Results 1 to 16 of 16
Thread: Under body treatment
Hybrid View
    Oct 2018
    What do most builders do about coating/painting the underbody of the roadster?
    I used Herculiner roll-on bed liner.
    Others have used a similar product from Duplicolor.
    https://www.amazon.com/Dupli-Color-B...omotive&sr=1-2
    Tybee Island, GA
    This is the one I used per recommendation of Jeff Kleiner. Water based for easy cleanup.
    Videos are at: YouTube Videos
    Herculiner, Bed Armor, rubberized undercoating or nothing at all. Some owners do it themselves, others have me do it when I paint the car.
    BadAsp427's Avatar
    Greeneville, TN
    I followed the lead from one of the best, Jeff K.... Very easy to use, clean up and very very low odor.
    Raptor Bed Liner In Red To Match The Color Of The Car!
    U-Pol Raptor Blood Red Urethane Spray-On Truck Bed Liner Kit w/Free Spray Gun, 4 Liters
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    What is the benefit of covering the underside? Is it cosmetic only or are there concerns with rocks/debris hitting the underside of the body and causing damage? I know people apply this but wasn't quite sure why.
    Quote Originally Posted by dbo_texas View Post
    Purely cosmetic in my opinion. I didn't want to see red, unfinished fiberglass from the underside of a blue car.
    Tybee Island, GA
    My reasons were a little of both.
    I wasn't going to paint the underside completely, but instead just hit the wheel wells heavy. But later I learned from Kleiner that painting the entire underside helps its appearance when you see it as you open the hood, or trunk, etc. He was right that it made a positive difference in appearance. No more seams in view. As for the wheel wells, I ended up going VERY heavy in there to help provide some rock cushion/protection. I did many layers in the wheel wells and even went as far as pouring it in that area before spreading out.
    Let it bake in the hot sun for hours, and you're good.
    20180428_092323 by D. R., on Flickr
    20180428_121046 by D. R., on Flickr
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I wanted to seal the underside of the body against moisture and also re-enforce it from rock strikes. I've seen a couple of cars that had star cracks on the nose from rocks that bounced off the radiator and hit the underside of the nose. Not saying that the undercoating will stop all of that, but it won't hurt.
    Ray
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Okay, so I'm going to come across as more than a little OCD with this reply. I did coat the wheel well area with bed liner (just the fiberglass - not the aluminum panels), but the rest of the interior surface was smoothed with slick sand and sanding, then I applied an aluminum appearance paint (Eastwood Alum-a-Blast) using a dry brush technique, in order to replicate the appearance of mill-finished aluminum.
    I even went so far so as to put in a bunch of 1/4 moon shaped divots using a small sanding disk so that it would look like hammer marks.
    Most of the inside of the body isn't visible once done, but there are some spots that you can see, like inside the engine bay near the footboxes and near the door hinges.
    Here's a shot of the rear passenger side wheelwell area before I applied the bed liner - since this was covered with bed liner, I hadn't smoothed the fiberglass as much as I did in the visible areas.
    Later,
    Mk3.1 #7074
    Are any of the undercoatings able to be painted? I’d like to follow Chris’s lead and undercoat, then paint to look like aluminum
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    I went with Rust-Oleum Truck Bed Liner and have been pleased to date.
    I coated the entire underside of the body and plan to add extra coats to the wheel wheels. It went on easy and dried fast. Based on my research it is a little thinner than some of the other bed liners mentioned, which worked well for coating the fiberglass and providing a smoother finish. For a truck bed would probably want a thicker product.
    Mark Eaton's Avatar
    Medford, Oregon
    I am planning to use on of the spray on products and I will go ahead and do my truck bed at the same time. I have read in other posts that it not only protects the body but does add a "solid" feel to the car and may reduce road noise...
    Mark
    I painted the underside with black epoxy paint, to seal it. I later applied undercoating, to the wheel wells.
    Dec 2013
    Sandia Park, NM
    I added wheel well liners from Alex Dailey
    http://acroadsterinteriors.com/Fenderliners.html
    to hopefully avoid star cracks from rocks being thrown up by the tires.
    I'm also considering spats on the rear fenders to help protect against rocks from the tires. After about 6000 miles, I have one chip on the driver's side rear fender from a rock (probably).
