Hope this pic is visible. The cable mounting housing only has one screw to mount???
This seems kind of flimsy. Is there any other part that's supposed to be used?
Your clutch quadrant will grab that metal end and hold the cable in place up against the forward DS footbox wall. I think I took that mount tab off my cable so it would fit in the adjuster that I purchased. See pic:
2019-02-15_03-45-00 by D. R., on Flickr
Videos are at: YouTube Videos
That cable is like the one I have on my Coupe. No firewall adjuster and the part with the bolt hole just fits in the hole in the aluminum at the pedal box. Clutch adjustment is done at the clutch fork.
David W
Mkll 4874 built in 2004
