Results 1 to 5 of 5
Thread: Wiring routing for electric. PS
    Loveland, CO
    I will be looking for alternate PS wire routing than that shown on page 146 of the assembly manual. The manual shows routing outside the 1.5” firewall support. I just ripped mine to shreds test fitting the cab. I am working by myself using a lift to drop/lift the cab. Maybe, if you have multiple helpers pulling the sides out you could make it work, but that is not always convenient.
    The brake lines, also mounted there, are strong enough to withstand the abuse, but not wiring.
    Just my experience.
    Ralph
    Senior Member Marv's Avatar
    Nov 2012
    Tucson, AZ
    Here are pictures of mine,wiring harness is the smaller of the two.
    2008 FFR 5851 Copperhead Orange with ghost stripes by “the Bat”, Ford Racing 345 HP, Tremec 5 Speed
    2012 FFR 33 HR, won Best Use of Chrome Huntington Beach 2014; 345 HP AOD
    Deep Impact Blue
    2018 FFR 35 Pick Up, building, getting there.
    Loveland, CO
    Marv, thanks. I will probably go someplace similar, when I get the body back off.
    Ralph
    herb fraser's Avatar
    I cant post a pic as I am out of town , however I spliced wire to extend them and mounted the unit going through the firewall , inside under the dash, This will of course keep it out of the weather and hopefully extend its life.
    Herb
    Senior Member Robodent's Avatar
    Aug 2018
    Hampshire, IL
    I also extended the wires and fabricated a mounting plate and installed the module under the dash.
